  • Hitting the apex
  • Member For: 16y 8m 6d
Brian you.are more than welcome to see if you can get it down the strip quicker. It would be good to compare actually
I have the car booked at autotech next week to see what power it is really putting out and if it's under 400 I think I will get them to have a go at a tune
  • Replies 64
  • Member For: 16y 24d
powerside there is a 5% difference in power figures between dynos but its also how you drive to get a good time at the track you have to do every thing right 12s is slow all the other guys that have tunes from tune house
around that power have run 11s even my self I ran 11.04 with 450kw @ 130mph with a slipping box. so get tony to check your car out there might be a problem.
  • Hitting the apex
It's been running mid 12's so I got the box fixed because it was toast... 3 k stall I'm revving to 2k when I drop the brake, if I go higher it just fries the tyres. 1st and 2 nd spin but 3 rd and 4 th are pretty good. I think for the power figure my half to full track mph should be 4 mph higher
I'll go get a new set of bridgestones today and go on Wednesday again, if you think you can get it down quicker you welcome to try
  • Member For: 17y 11m 30d
I told him to put it on a dyno to log boost and afrs and see what it is doing, he has the car booked next week, so lets just wait and see what the results indicate.
Maybe the convertor who knows, could be alot of things, lets see the graph when it gets done.
ive got the same converter it perfect when you take it to the track are you hitting limiter if your spinning that much your foot cant be flat the hole time so your mph wont be up !get some real tyres mickey thompsons or hoosiers then youll be able to run some good times those normal street tyres are sh*t for power over 300kw at the wheels so dont bother with the bridgestones
  • Hitting the apex
I have to ease off in 1st and 2nd so it stops spinning but it docent spin 3rd so the 1/2. And full track time should be higher
I have michelian slicks from a Porsche I can use... They are rubbish when cold but should heat up enough with a 10s burnout
Maybe then I could stall it to 3k
I'll look into the et streets, I just need a set of 15 or 16s to fit
those porsche tyres are for circuit they wont work 17 x 9 275 /40/ 17 will do the job and fit over the brakes youll need 35 offset rim so you dont scrape not 7or 8 inch rims not enough tyres contact get mickey et streets the ones with least amount of grooves in them.then you can launch alot harder but do a decent burn out.
  On 01/10/2010 at 11:19 PM, power_slide said:
Where's a good place to get 17x9's
taleb tyres near tempe you can get d1r lenso wheels about 250 each rim and they are light.
