FPV TRANNY Im the one and only Donating Members 3,557 Member For: 20y 5m 15d Gender: Male Location: In my house Posted 30/09/10 07:36 AM Share Posted 30/09/10 07:36 AM I was running 120mph with 310rwkw and a 3000rpm high stall.Definatley 121 mph should see mid to high 11,s.It just starts getting harder to get off the line clean when running bigger power. Link to comment https://www.fordxr6turbo.com/forum/topic/70794-wsid-tonight-290910/page/2/#findComment-1044143 Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 11m 28d Gender: Male Location: south east suburbs Posted 30/09/10 07:45 AM Share Posted 30/09/10 07:45 AM (edited) I ran 121mph to get 11.2, Dont think you have 420rwkw, you would of ran alot more mph than that.You either have a problem somewhere, eg id check the car over again, something is wrong, or that dyno is way off. Edited 30/09/10 07:49 AM by xr6t_ute Link to comment https://www.fordxr6turbo.com/forum/topic/70794-wsid-tonight-290910/page/2/#findComment-1044148 Share on other sites More sharing options...
power_slide Hitting the apex Donating Members 596 Member For: 16y 8m 4d Gender: Male Location: Miranda Posted 30/09/10 07:58 AM Share Posted 30/09/10 07:58 AM Is there a way that you can work out power between half track mph and full mph?I have traction issues and my pirelli p zero neros are on the wear markers... Box has done 1500ks since rebuildTunehouse has tuned it... After next tune I'll put it on another dyno to compare the figures Link to comment https://www.fordxr6turbo.com/forum/topic/70794-wsid-tonight-290910/page/2/#findComment-1044155 Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 11m 5d Gender: Male Location: Aspendale, Vic. Posted 30/09/10 01:10 PM Share Posted 30/09/10 01:10 PM I ran over 126mph and 11.7 ;(you can sort of work out what times your car can achieve with a timeslip that has 60", 1/4mile time and MPH.Aim is 1.6x 60". If you can get that, then your time wont be any quicker. 421rwkw with a convertor and only running 121mph? was it a hub dyno? Link to comment https://www.fordxr6turbo.com/forum/topic/70794-wsid-tonight-290910/page/2/#findComment-1044243 Share on other sites More sharing options...
power_slide Hitting the apex Donating Members 596 Member For: 16y 8m 4d Gender: Male Location: Miranda Posted 30/09/10 11:25 PM Share Posted 30/09/10 11:25 PM yea it was a hub dyno, it had 370+ before I did the injectors on a roller dynoI have a 2.1 60" and im slower at the end of the track WTF is the deal there Link to comment https://www.fordxr6turbo.com/forum/topic/70794-wsid-tonight-290910/page/2/#findComment-1044280 Share on other sites More sharing options...
jimmy1234 Donating Members 364 Member For: 17y 4m 14d Gender: Male Posted 01/10/10 12:52 AM Share Posted 01/10/10 12:52 AM power_slide, can you post up a time slip... I think 121mph is low for your 370+ but defiantly low for your 421.... I had 400ish (on the hub dyno) and would run consistent 126mph, even on the factory tyres I ran 11.5@125 mph...... Don't go comparing your MPH + rwkw Vs the 4 speeds cause they tend to run quicker et with lower mph.... But do get things looked at. Link to comment https://www.fordxr6turbo.com/forum/topic/70794-wsid-tonight-290910/page/2/#findComment-1044303 Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 11m 28d Gender: Male Location: south east suburbs Posted 01/10/10 05:32 AM Share Posted 01/10/10 05:32 AM What was your mph midtrack? Link to comment https://www.fordxr6turbo.com/forum/topic/70794-wsid-tonight-290910/page/2/#findComment-1044374 Share on other sites More sharing options...
power_slide Hitting the apex Donating Members 596 Member For: 16y 8m 4d Gender: Male Location: Miranda Posted 01/10/10 07:01 AM Share Posted 01/10/10 07:01 AM My monitor won't work at the moment so I have to use the iPad but I cannot scan to itThe sheet says the followingTemp. 0Rel humidity. 0Absoloute baro 30.14Track temp. 0R/T. .64360" 2.075330. 5.3701/8. 7.968MPH. 96.381000. 10.1701/4. 12.025MPH. 121.89 Link to comment https://www.fordxr6turbo.com/forum/topic/70794-wsid-tonight-290910/page/2/#findComment-1044387 Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 11m 28d Gender: Male Location: south east suburbs Posted 01/10/10 07:04 AM Share Posted 01/10/10 07:04 AM (edited) Definately doesnt have 420rwkw, your more around 350ish, doesnt look anything out of the ordinary going by the mid and end mph, the power that was quoted just isnt there. Looks more like your old tune, maybe check that you flashed the correct tune.I think the best bet is to go and run it up on the dyno and log boost and afr, and see what its doing. Edited 01/10/10 07:12 AM by xr6t_ute Link to comment https://www.fordxr6turbo.com/forum/topic/70794-wsid-tonight-290910/page/2/#findComment-1044388 Share on other sites More sharing options...
power_slide Hitting the apex Donating Members 596 Member For: 16y 8m 4d Gender: Male Location: Miranda Posted 01/10/10 07:12 AM Share Posted 01/10/10 07:12 AM I have tried a few different tunes and there is sweet fa difference between them.. I think it was .2 different Link to comment https://www.fordxr6turbo.com/forum/topic/70794-wsid-tonight-290910/page/2/#findComment-1044389 Share on other sites More sharing options...
