234Fpv Donating Members 522 Member For: 13y 11m 25d Gender: Male Location: Yeppoon qld Posted 16/11/11 09:06 AM Share Posted 16/11/11 09:06 AM Yeah I just don't want to kill my phone. Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/page/4/#findComment-1160270 Share on other sites More sharing options...
ITS 71M Member 35 Member For: 13y 9m 18d Gender: Male Location: sydney Posted 16/11/11 02:19 PM Share Posted 16/11/11 02:19 PM I have used it to. but have only tried it on a n/a xr6 and it says throttle position is 14% on idle to me I dont think that is right but could be wrong. I hope it works on the turbo when I get it back. but for what it is seems to be a good app Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/page/4/#findComment-1160395 Share on other sites More sharing options...
(AUST)Mod Member 29 Member For: 14y 3m 16d Posted 17/11/11 03:23 AM Share Posted 17/11/11 03:23 AM I received my ELM 327 today and it seems to be working. However, the app says "faulty OBD2 adaptor" at the bottom and displays 200 odd errors in the OBD adaptor section. Is this normal? Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/page/4/#findComment-1160501 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 5m 24d Posted 17/11/11 06:11 AM Share Posted 17/11/11 06:11 AM (edited) Nope, mine did the same, sent it back. it was still counting at 700+ errorsIt should read 0 errors.It seems alot of the cheap Chinese ones have these problems, or will be working fine then just die.My Samsung Galaxy gets hot too when using bluetooth or internet heavily. Think its just the processor being worked harder + battery drain.If it fails, get a new one under warranty. your only using it for what it was designed for. Edited 17/11/11 06:12 AM by 1600dave Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/page/4/#findComment-1160544 Share on other sites More sharing options...
Ale Member 249 Member For: 13y 10m 8d Posted 17/11/11 09:54 AM Share Posted 17/11/11 09:54 AM elm 327: This one seems to be the smallest one on the market and by measurements will fit with the cover on, can anyone confirm?http://www.ebay.com.au/itm/Mini-ELM327-OBD-II-OBD2-CAN-BUS-Small-Bluetooth-Adapter-/380377955555?pt=Motors_Automotive_Tools&hash=item58904afce3 Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/page/4/#findComment-1160719 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 5m 24d Posted 17/11/11 10:28 AM Share Posted 17/11/11 10:28 AM I think someone said somewhere that the plug can be unclipped from the fuse box and pushed back so that the cover will still fit with pretty much any of the adapters. Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/page/4/#findComment-1160734 Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 7m 29d Gender: Male Location: Muswellbrook,NSW Posted 17/11/11 10:47 AM Share Posted 17/11/11 10:47 AM Iphonrs users :u need an app call REV and the ebay dongle to get is called KiwiWiFi (its a wifi based dongle as the iphone has a poor bluetooth connectivity, or you can use the ELM 327 based bluetooth, but require a jailbroken iphone and a bluetooth stacker app Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/page/4/#findComment-1160747 Share on other sites More sharing options...
Ale Member 249 Member For: 13y 10m 8d Posted 17/11/11 09:37 PM Share Posted 17/11/11 09:37 PM I think someone said somewhere that the plug can be unclipped from the fuse box and pushed back so that the cover will still fit with pretty much any of the adapters.really? Il have to take a closer look, but I must say Id prefer not to touch the clip, just plug in and play Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/page/4/#findComment-1160811 Share on other sites More sharing options...
KeepLeft Member 240 Member For: 16y 2d Gender: Male Posted 20/11/11 03:34 AM Share Posted 20/11/11 03:34 AM (edited) To everyone whinging about faulty obd adapters; it's all explained here: http://torque-bhp.co...etooth_AdaptersAdapter from China/via ebay/amazonMany units seem to suffer poor build quality and reliability issues. Some units are perfectly fine. Make sure you purchase with a buyer who has a decent returns policy should the unit turn out to be defective. I would recommend avoiding this adapter, *especially* if you intend to use it on a Ford or other vehicle which uses the J1850-PWM protocolEdit:1600dave is correct. Unclip the odb plug as it has a decent length cable on it. That way you can plug the adaptor in to it and have the sender/receiver and most the cabling neatly hidden away behind the kick panel under/behind the fuse box. Edited 20/11/11 03:38 AM by KeepLeft Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/page/4/#findComment-1161351 Share on other sites More sharing options...
dule Donating Members 1,180 Member For: 18y 2m 17d Gender: Male Location: Sydney Posted 21/11/11 02:53 AM Share Posted 21/11/11 02:53 AM My adapter arrived, I got one of the smaller ones of ebay and I can plug it in and put the fuse cover back in. Just not sure if it's ok to leave it plugged in as I've noticed a light stays on after turning the car off so will have to look in to it.The free app doesn't have oil temp or pressure available so will get the paid one and see if that has it. Is it really normal for these cars to have coolant temp go over 100 and temp needle is still below half way? Do they really run this hot? Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/page/4/#findComment-1161599 Share on other sites More sharing options...
