rule1110 Member 71 Member For: 17y 2m 1d Posted 20/09/10 03:00 AM Share Posted 20/09/10 03:00 AM Hi thereJust wondering if anyone has used the Torque app for android? I see there are similiar ones for iphones. I have just ordered a cheap obd2 bluetooth adapter off ebay so just waiting for it to come in the mail. Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/ Share on other sites More sharing options...
Hunia Member 2 Member For: 17y 4m 10d Gender: Male Posted 27/09/10 08:13 AM Share Posted 27/09/10 08:13 AM I bought an elm 327 bluetooth adaptor and have it plugged into my 2003 BA XR6 turbo ute, Used the free Torque app from the android market for a few days. Was very impressed so paid out for full version today. Is a great app, well worth $5. Havent figured out a few of the gauges yet but most are working. Have a capa flasher and run 15psi boost. is nice too have a bit more information available fron the ecu Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/#findComment-1043373 Share on other sites More sharing options...
rule1110 Member 71 Member For: 17y 2m 1d Posted 27/09/10 10:20 AM Author Share Posted 27/09/10 10:20 AM Good to hear it works. I'm still waiting on my bluetooth adapter from ebay. I have an old iphone 3g I want to try as well , I was looking for apps for it but they all seem to use a wifi obd2 adapter which was a bit dearer than 30 bucks. Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/#findComment-1043429 Share on other sites More sharing options...
Stazza_Brendan Donating Members 686 Member For: 15y 8m 22d Gender: Male Location: Mackay QLD Posted 27/09/10 12:42 PM Share Posted 27/09/10 12:42 PM Got a screenshot of the screen?Ive got a similar sounding setup in mine but using a GPS looking device called a DashDAQ, touch screen, customisable gauges that read from OBD2 port.Quick pic from when I was first playing with it. Got the same screen running MAP, trans temp, oil temp, intake temp, coolant temp and a shift light.Can also run other screens like the homepages on a smart phone, just click to the next set of gauges Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/#findComment-1043488 Share on other sites More sharing options...
rule1110 Member 71 Member For: 17y 2m 1d Posted 28/09/10 06:07 AM Author Share Posted 28/09/10 06:07 AM bit of a bummer, when it connects to the bluetooth adapter is its says, incompatiable ECU, but torque will still try to read the data anyway.It manages to read the boost and coolant temp. Coolant temp seems about right. The boost stays on -9.9 psi at idle and when you drive it gets back to nearly 0. If you wind it right out it got to 5psi. Might have got to 6psi if I really pushed it but I couldn't really test it much cause its pouring rain. Hunia - Where did you getyour adapter from and does it all work properly. Mine was a $30 ebay job from hong kong so I can't expect too much. Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/#findComment-1043609 Share on other sites More sharing options...
Hunia Member 2 Member For: 17y 4m 10d Gender: Male Posted 28/09/10 08:41 AM Share Posted 28/09/10 08:41 AM I bought my bluetooth adaptor from trademe in NZ, looks the same as others I have seen on ebay from China. Mine also says incompatible ecu on starting app but then tries to read data and mostly works. Havent figured out how to get a couple of the gauges going but most work fine. will get a video up at weekend on youtube with a link on this thread. Have emailed developer for help to add extended PIDs and fix issues.List of gauges I use that work are Boost, Speed, Revs, Timing advance, Intake air temp, Coolant temp, Acceleration, Engine load, Fuel trim, O2 volts, Altitude. Havent tried quarter mile,0-100km/h, horsepower, torque, fuel level, fuel pressure, MPG, or barometric pressure. Gauges I havent got working yet are voltmeter(dont need as my bel radar detector is set to read volts) and throttle position sensor. Will experiment more this weekend.My Ute has been modified mostly by first owner , has no cat or 02 sensor in exhaust so not sure how this will affect ecu data, also have flashed with CAPA tuner and boosts to 15psi on a grippy surfaceRunning Torque App on a Nexus one and have been trying different screen layouts, have been trying to get cooler air into engine so mainly watching intake air temp on way to work to see what effects my efforts are having.Have been trying to add extended PIDs codes for Knock retard with as have had problems with missing before I changed coil packs.Havent looked at error codes yet either Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/#findComment-1043642 Share on other sites More sharing options...
rule1110 Member 71 Member For: 17y 2m 1d Posted 29/09/10 10:45 AM Author Share Posted 29/09/10 10:45 AM I got all those same guages working now. Pretty cool app, I bought the full version cause its only $4.80 AU and might as well support the developers because they will continue to improve it. I've only got my boost to 5psi on my standard ba xr6t. If you were keen enough you could buy one of those 7 inch android tablets and make yourself a cool set of guages just don't know where you would put it.So far only got boost, revs and coolant temp to read. I do have a Nokia Bluetooth kit in the car so I might try it again with that disabled. does you boost read -9.9 psi at idle? Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/#findComment-1043916 Share on other sites More sharing options...
234Fpv Donating Members 522 Member For: 13y 11m 24d Gender: Male Location: Yeppoon qld Posted 23/10/11 02:00 PM Share Posted 23/10/11 02:00 PM I was thinking the same thing if they are accurate Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/#findComment-1153022 Share on other sites More sharing options...
rbjet Skid Machine Donating Members 1,640 Member For: 14y 1m 9d Gender: Male Posted 23/10/11 08:31 PM Share Posted 23/10/11 08:31 PM Ive downloaded the app and now I'm just waiting for the dongle to arrive which should be sometime this week so ill keep you guys posted on how I go. I just bought the cheap ELM one from china. $17, cant go wrong. Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/#findComment-1153032 Share on other sites More sharing options...
234Fpv Donating Members 522 Member For: 13y 11m 24d Gender: Male Location: Yeppoon qld Posted 23/10/11 11:57 PM Share Posted 23/10/11 11:57 PM Yeah I just bought a Bluetooth dongle off Ebay. Might have to unclip the obd2 plug and relocate it so I can still have the plastic cover on. I bought the smallest dongle I could find on there. Link to comment https://www.fordxr6turbo.com/forum/topic/70624-anyone-tried-the-torque-app-for-andriod/#findComment-1153077 Share on other sites More sharing options...
