ofa180 Member 72 Member For: 19y 6m 26d Gender: Male Posted 19/09/10 04:31 AM Share Posted 19/09/10 04:31 AM (edited) I recently noticed a light vibration through the driveline at mild exceleration levels in my TT,it happens from 60km/h to 90km/h.Anyone had the same problem? Its not there when you granny it or when you floor it,just in between. Edited 19/09/10 04:32 AM by ofa180 Link to comment https://www.fordxr6turbo.com/forum/topic/70611-slight-vibration/ Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 9m 21d Gender: Male Location: Victoria Posted 19/09/10 07:12 AM Share Posted 19/09/10 07:12 AM Does it do it at a set speed?Could be wheel balance? Tailshaft... Many things!!! Link to comment https://www.fordxr6turbo.com/forum/topic/70611-slight-vibration/#findComment-1041349 Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 3m 13d Posted 19/09/10 08:59 AM Share Posted 19/09/10 08:59 AM Have you had any repairs done recently? Such as front or rear diff bushes. You may require a front and rear tailshaft balance which can be done at your dealer. Link to comment https://www.fordxr6turbo.com/forum/topic/70611-slight-vibration/#findComment-1041393 Share on other sites More sharing options...
ofa180 Member 72 Member For: 19y 6m 26d Gender: Male Posted 20/09/10 07:05 AM Author Share Posted 20/09/10 07:05 AM No recent work done,the vibration starts around 60km/h & goes away at around 90km/h. I'll have a look under it once I get a chance. Link to comment https://www.fordxr6turbo.com/forum/topic/70611-slight-vibration/#findComment-1041645 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m 7d Gender: Male Location: SW Sydney Posted 20/09/10 07:07 AM Share Posted 20/09/10 07:07 AM Front diff bushes are becoming more and more common, unfortunately we haven't got an aftermarket option yet. Link to comment https://www.fordxr6turbo.com/forum/topic/70611-slight-vibration/#findComment-1041647 Share on other sites More sharing options...
ofa180 Member 72 Member For: 19y 6m 26d Gender: Male Posted 21/09/10 07:45 AM Author Share Posted 21/09/10 07:45 AM Had a look today,it seems it the front diff bushes.Whats the price on these things? bushes only & fitted price also? Link to comment https://www.fordxr6turbo.com/forum/topic/70611-slight-vibration/#findComment-1041959 Share on other sites More sharing options...
blownaway Member 19 Member For: 18y 12d Posted 10/10/10 01:38 AM Share Posted 10/10/10 01:38 AM (edited) My TTG had the same problem, the tail shafts and the drive shafts had to be replaced it was about $6000 worth of work.ford replaced it under warranty it a common problem in the TTG. All the rear bushes were replaced 5000km later under warranty ford were great about it because warranty had run out about 2 months before. Edited 05/11/10 08:34 AM by RHR No need to quote above post. USE FAST REPLY Link to comment https://www.fordxr6turbo.com/forum/topic/70611-slight-vibration/#findComment-1046524 Share on other sites More sharing options...
ofa180 Member 72 Member For: 19y 6m 26d Gender: Male Posted 05/11/10 05:06 AM Author Share Posted 05/11/10 05:06 AM Well I was wrong,on further inspection,it's not the bushes,the front left wheel bearing has collapsed,haven't had a chance to pull it apart to check the total damage,ie hub etc.Has anyone heard of this happening to a territory?I'm away from the vehice & had the mrs take it to the local ford dealer. After reading through all this http://www.carbuddy....spx?t=2&tid=667it sounds more like the ball joint has failed. I'm just glad she wasn't injured or anyone else as the wheel is just about to fall off! Link to comment https://www.fordxr6turbo.com/forum/topic/70611-slight-vibration/#findComment-1053196 Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 8m 9d Gender: Male Location: Southern Highlands NSW Posted 05/11/10 08:42 AM Share Posted 05/11/10 08:42 AM pics? Link to comment https://www.fordxr6turbo.com/forum/topic/70611-slight-vibration/#findComment-1053239 Share on other sites More sharing options...
ofa180 Member 72 Member For: 19y 6m 26d Gender: Male Posted 09/11/10 05:09 AM Author Share Posted 09/11/10 05:09 AM Well it turns out it was the wheel bearing. Got the new bearing in,but there is still a small amount of play in the hub,so unfortunately I will have to get a new hub assembly. Does anyone have any recommendations who to buy through? So far got price from ford & FTG auto salvage,best is FTG for $550 with new bearing. Link to comment https://www.fordxr6turbo.com/forum/topic/70611-slight-vibration/#findComment-1054274 Share on other sites More sharing options...
