Fg Stereo Hiss
FGX 40T
  • Member For: 14y 7m 4d
Hi I hoping someone can help. Just got a stereo upgrade - Alpine SPR-17S Component speakers(front doors and pillars for tweeters), Alpine SPR-17C Coaxial(rear doors)running through Alpine MRP-F600 Amp. I am getting a very annoying hiss from all speakers. The installer tells me it is from the factory unit and the hiss is simply being amplified and now more audible due to better speakers. It was installed using the high level inputs as this is what was recommended. After I took the vehicle back they tried using line level converters to RCA but still no difference. They did all the usual checks, earth length and connection - but still no good. In the end they turned the gain down on the amp. This helped a little with the hiss, but now the system is not as powerful. Very unhappy. I would prefer not to install another head unit as I wish to retain the factory appearance and functionality. Any advice would be appreciated.
  • Replies 26
Posted Images
  • FREAKY
  • Member For: 14y 10m 15d
is it alternator whine? as dillz mentioned going up n down with revs?
could be a crappy grounding in the system somewhere
there are a number of possible factors causing it, speaker wires/rca's too close to power cables, is everything grounded to the same point? etc etc
Thanks - The hiss remains constant - does not change with revs. According to the installer, it is a common earth - but I will check this and the location/length and quality of cable. I am going to try and get them to hook up an aftermarket head unit to test the integrity of their install. If the hiss goes, then I can assume they may be right and it is from the factory unit, if the hiss remains than it must be the install. Any other ideas?
  • Member For: 15y 4m 8d
There is definitely a hiss the standard "premium" head unit. If that's what you're using for the input then I'm betting that's what it is. I'm waiting for someone to do the BA/BF RCA pre-out mod for the FG unit before doing any stereo mods to my car.
  • Member For: 17y 1d
Was told by my auto sparkie most of our cars dont have enough earthing by a long shot. Easy answer is to fit a off the shelf earth strap between the engine and chassis, apparently solves a lot of common probs, and is a cheap easy first try I reckon.
I had alternator whine on the ba, turned out to be a bad earth.
Unfortunately I do not even have the Factory premium - I have the standard Ford sound system (poverty pack) - Demo vehicle no choice. The Earth lead is the same size and quality as power lead and bolted to the chassis close to the amp. I will definitely get another Earth lead attached as suggested and let you know if this works/helps. However what do you mean re: the RCA pre-out mod for FG's. I know nothing about this can you elaborate for me please.
Also when I spoke to the installer about patching in a headunit to test they said it was a lot of work and then made the following offer. They said they would will fit a new head unit, rewiring using RCA inputs (only charge for the headunit) and guarantee it will stop the hiss. If it does not, they will remove it (the head unit) and not charge me for it. I would really like to retain the factory system but it seems the only way to get rid of the hiss is with an aftermarket head unit. Someone did mention (on a forum site) it may be to do with the signal output from the factory unit only supplying a very small voltage (starving the amp for signal quality) as opposed the aftermarket units that supply a much stronger signal (more voltage). Anyone know anything about that?
  • Member For: 15y 10m 14d
It's the factory head-unit. Premium is the same (what I have). Using all awesome gear, but factory head-unit = hiss. Worse through iPod connector, but still there through CD. Installer hooked up an aftermarket headunit via RCA. An entirely different type of sound. Clean, crisp, with an awesome dynamic range. No comparison to factory headunit. But I, like you, wanted to retain the factory headunit. So for now I'm putting up with sub-par sound, with terrible hiss, (not alternator whine), until it sh*ts me enough to install another headunit in the glovebox (FPV has the stupid Start button where an aftermarket head unit would normally mount).
If anyone knows of a way to fix the factory hiss, I'm all ears. I'm using a Cache line-level converter, but from what I've read, the hiss is still there even with units like the Audison Bit One.
Garbage In = Garbage Out.
Simon
Edited by SimonT
