quadie Donating Members 720 Member For: 19y 24d Gender: Male Location: Muswellbrook,NSW Posted 03/01/11 05:24 AM Share Posted 03/01/11 05:24 AM Yes , ICC has filters when it detects the std premo amp are u inending to use the signal going to the premo amp or out of the premo amp?if u use the signal before it is only about .5V p-p not big enough to drive a monoblock so u wil need a PRE AMP to boost it before the monoblockif you use the signal after the premo amp u will need a HI-LO converter such as the LC6ithe best way ist o disabe the premo amp (unplug it) and use a HI-LO convertor off the rear chanels Link to comment Share on other sites More sharing options...
markdc Member 9 Member For: 15y 7m 1d Posted 03/01/11 09:11 AM Share Posted 03/01/11 09:11 AM I was intending to use the signal going into the stock amp as a high level input for my mono, butas you have pointed out when I tested the voltage it was peaking at around .3V.So if I use a HI-LO converter such as the lc6i off the rear channels am I correct in saying It will noteffect my rear speakers which will be also using this signal amplified through a seperate amp?are there any downsides to using a pre- amp if I wanted to choose that option and use the input beforethe factory sub? Link to comment Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 24d Gender: Male Location: Muswellbrook,NSW Posted 05/01/11 10:53 AM Share Posted 05/01/11 10:53 AM it only samples the signal. doesnt take power away from rears1 big bonus of the LC6i is its GTO feature (Great Turn On)what it does is when it sees signal on the rears it turns your amp/s on (IE the 1 hour keyless play will work )instead of hooking it up to ACCyes u have no control of the X-over oint if you use the actory sub output Link to comment Share on other sites More sharing options...
