seduced Need more power. Now taking donations. Member 753 Member For: 15y 11m 24d Gender: Male Posted 15/09/10 11:10 PM Share Posted 15/09/10 11:10 PM If the factory amp is unplugged, the full signal is sent to the speakers. Otherwise, you could just run your new amp off the factory one, you wont blow anything up. Plug it in and see if you like it.I'll have to dig out he BA manual on CD I have somewhere. The wiring diagram was from that. Link to comment Share on other sites More sharing options...
FAST-XR EVIL T Member 259 Member For: 16y 2m 11d Gender: Male Location: Liverpool NSW Posted 16/09/10 04:34 AM Author Share Posted 16/09/10 04:34 AM thanks guys. I spliced one RCA lead directly into the wires that power the sub, and plugged it straight into the amp. works perfectly! Link to comment Share on other sites More sharing options...
FAST-XR EVIL T Member 259 Member For: 16y 2m 11d Gender: Male Location: Liverpool NSW Posted 16/09/10 05:58 AM Author Share Posted 16/09/10 05:58 AM (edited) also the sub inputs from the icc are the yellow(+) and black(-) wires (next to the 2 blue wires) the signal was way too week even with 2 channels bridged on the amp, I then took the input from the wires driving the sub (coming out of factory amp) and it cranked hard with just one channel! Edited 16/09/10 06:05 AM by FAST-XR Link to comment Share on other sites More sharing options...
FAST-XR EVIL T Member 259 Member For: 16y 2m 11d Gender: Male Location: Liverpool NSW Posted 16/09/10 06:07 AM Author Share Posted 16/09/10 06:07 AM and heres a wiring diagram I found that might be helpful for people in the futureEntertainment_Sys1.pdf Link to comment Share on other sites More sharing options...
markdc Member 9 Member For: 15y 9m 23d Posted 28/12/10 05:14 AM Share Posted 28/12/10 05:14 AM also the sub inputs from the icc are the yellow(+) and black(-) wires (next to the 2 blue wires) the signal was way too week even with 2 channels bridged on the amp, I then took the input from the wires driving the sub (coming out of factory amp) and it cranked hard with just one channel!can anyone confirm that the yellow and black wires next to the blue ones are the SUB + AND - from the ICC?THANKS Link to comment Share on other sites More sharing options...
Rudiger All round good guy! Lifetime Members 1,122 Member For: 16y 9m 11d Gender: Male Location: Greenvale, Victoria Posted 28/12/10 08:04 AM Share Posted 28/12/10 08:04 AM My research (half assed as usual) suggested you take a line off one of the rear speakers, run it through a hi-lo converter to a mono amp and run the subby off that. Havent done mine yet. Got all the bits but that was how I was told to do it. Link to comment Share on other sites More sharing options...
xr6turbs boosting Donating Members 391 Member For: 18y 7m 30d Gender: Male Location: Glendene, Auckland NZ 0602 Posted 28/12/10 09:07 AM Share Posted 28/12/10 09:07 AM Fast-XrJust to clarify as my factory sub has decided to pack itself....You have spliced RCA plugs from the wires that are FROM the amp to the factory sub and used these wires which are plugged into your new amp and sub combo? ORRRR have you spliced the RCA prior to entering the factory amp? Link to comment Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 3m 16d Gender: Male Location: Muswellbrook,NSW Posted 29/12/10 11:05 AM Share Posted 29/12/10 11:05 AM (edited) the high level input to the premo amp is LOW PASS (ONLY BASS)in the premo system if the CAN bus see's the amp the ICCENABLES filters on all outputstherefore.Yes you can use the High level input but it will need PRE-AMP before u feed a MonoblockIF you tap of the Rears(Or fronts)u must disconnect the Premo amp to allw full range to the rear channels.if you tap rears , u need a good converter not a cheap 20 buck stinger job.I use and reccomend the Audiocontrol LC6i ($279 JB HIFI). if SQ s what your chasingdo away with the ICC Completley. If u still wat SQ with the ICC , RF 360.2 ? (around 700)will do what you wantif u only want good sound for 20 bucksdo m RCA for ICC guide its sounds alot better than any 20 Hi-Low convertorloading an amp up with the amped premo signal is not a wise idea, u will be overdriving the input which will clip the waveform causing unwanted distortion even at low VOL levels Edited 29/12/10 11:09 AM by quadie Link to comment Share on other sites More sharing options...
Rudiger All round good guy! Lifetime Members 1,122 Member For: 16y 9m 11d Gender: Male Location: Greenvale, Victoria Posted 29/12/10 12:57 PM Share Posted 29/12/10 12:57 PM In english please dude.All I got was JB Hi fi for $279 and that was about it. Link to comment Share on other sites More sharing options...
markdc Member 9 Member For: 15y 9m 23d Posted 03/01/11 04:26 AM Share Posted 03/01/11 04:26 AM the high level input to the premo amp is LOW PASS (ONLY BASS)in the premo system if the CAN bus see's the amp the ICCENABLES filters on all outputstherefore.Yes you can use the High level input but it will need PRE-AMP before u feed a MonoblockIF you tap of the Rears(Or fronts)u must disconnect the Premo amp to allw full range to the rear channels.so your saying if you plug in the Factory amp then the ICC sensors this and enables a high pass filter to the 4 in car speakers, because it thinks that you are running your sub for bass therefore the fronts and rears dont need the bass frequencies.im not to keen on spliting the fronts or rears in order to run a signal to my aftermarket sub im looking to install, so if I wanted to utelize the yellow/black LOW PASS signal that would normally be fed into the factory amp would I require a pre-amp device such as a lc6i, mtx re-q? Link to comment Share on other sites More sharing options...
