velocity6t Inactive Members 1 Member For: 14y 4m 1d Posted 25/10/10 01:26 AM Share Posted 25/10/10 01:26 AM I need help from all you "gurus" with a rough idle & stalling at idle problem. I have a BA turbo ute, stock as a rock & came on the forum a few month back with the same problem and it was suggested a new TPS would sort the problem. I replaced it & really shouldn't have touched a spanner on that particular day (complete clusterf**k day), anyway it didn't sort the problem and it has been suggested an Oxygen Sensor is what's needed. Any suggestions will be greatly appreciated and thanks in advance. Tony.Hi tony im new to this site but here goes anyway......... turbos run very high pressures and this causes thing to loosen up a little to sum it up quite simply u need to check out the exhaust manifold for loose bolts the need to be from memory 27 newton meters tight but u need to check out the correct torquing of these exhaust manifold bolts this can cause the engine to shake and shudder and rough idle issues....the oxy senor will only calculate the richness or lean mixtures and send that info to the engine management systems to sort out the fuel mixture it wont cause what your stating in your comments....... hope this helps tony ....Bill....... Link to comment Share on other sites More sharing options...
mrmackie Donating Members 67 Member For: 17y 5m 7d Gender: Male Location: Perth - CBD Posted 25/10/10 12:45 PM Share Posted 25/10/10 12:45 PM the oxy senor will only calculate the richness or lean mixtures and send that info to the engine management systems to sort out the fuel mixture it wont cause what your stating in your comments....... hope this helps tony ....Bill.......From personal experience, I disagree.I had exactly the same probs with my STOCK BF06 T idling very rough to the point of almost stalling, especially on cold mornings, but it then disapears when the car warms up. Took it into ford approx 8 times, 6 times under warranty to try and find the problem, with them having it for a week. They replaced various small items with absolutly Sweet FA effect. I cleaned the TB, checked all piping, changed the TPS but it still didnt fix the problem. Finally bought a O2 sensor from Ebay and,........................it solved my problem!!!!, and also improved my fuel consumption by approx 80 extra k's per tank. For the $60 I spent on it, it has given back my faith in my Ford T. Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 9m 6d Posted 25/10/10 11:40 PM Share Posted 25/10/10 11:40 PM Yeah you cant go wrong with changing your 02 sensor at around 100,000KMS anyway...and they are quite cheap on ebay...its not hard to replace yourself either as long as the old one isnt jammed tight onto the manifold. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 3m 1d Gender: Male Location: Probably above atmospheric pressure Posted 26/10/10 02:33 AM Share Posted 26/10/10 02:33 AM Oddly enough my idling has been ok recently even after 1/4 mile runs and a 1kw (woo) final tune power increase. I like the idea of more economy though for a $60 part! Link to comment Share on other sites More sharing options...
neil101 Donating Members 123 Member For: 19y 4m 13d Gender: Male Location: Kurrajong Heights NSW Posted 31/10/10 12:27 AM Share Posted 31/10/10 12:27 AM Check your intake manifold gasket commonly pron to the gasket breaking and causing rough idle and stalling and it mostly overlooked as a cause the gasket goes brittle and breaks commonly around no 1 and 2 cylinder no 5 occasionallygood way to check is get a watering can and pour water over the manifold as close to the head as u can if the idle goes really rough thiers your problem.Neil 1 Link to comment Share on other sites More sharing options...
IBOO57 Member 538 Member For: 15y 8m 12d Posted 31/10/10 10:52 PM Share Posted 31/10/10 10:52 PM (edited) Yep change your O2 sensor I had the same cold start idling issues. Edited 31/10/10 11:01 PM by IBOO57 Link to comment Share on other sites More sharing options...
DUS12 Member 471 Member For: 17y 7m 20d Posted 31/10/10 11:52 PM Share Posted 31/10/10 11:52 PM I still have this problem, I have traced it back to 302degree cams Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 25d Gender: Male Location: Adelaide Posted 01/11/10 03:30 AM Share Posted 01/11/10 03:30 AM I had the same prob but I found my flux capacitor was incorrectly dialing in the year ..............its now sweet 1969 and smooth easy beats all the way Link to comment Share on other sites More sharing options...
Banned1 Banned Banned 734 Member For: 14y 5m 13d Gender: Male Location: Caloundra Posted 01/11/10 04:21 AM Share Posted 01/11/10 04:21 AM I had the same prob but I found my flux capacitor was incorrectly dialing in the year ..............its now sweet 1969 and smooth easy beats all the way winter was cold but summer of 69 was good ! back on topic, my EF wagon now has a poor idle after I done the head gasket, I reckon the fuel pump is tired (noisey) and also the fuel rail O ring may have been damaged as its hard to crank over and needs primed 3/4 times... oh the joys ! Link to comment Share on other sites More sharing options...
