stillcruizin Member 7 Member For: 14y 9m 23d Posted 09/09/10 08:00 AM Share Posted 09/09/10 08:00 AM I need help from all you "gurus" with a rough idle & stalling at idle problem. I have a BA turbo ute, stock as a rock & came on the forum a few month back with the same problem and it was suggested a new TPS would sort the problem. I replaced it & really shouldn't have touched a spanner on that particular day (complete clusterf**k day), anyway it didn't sort the problem and it has been suggested an Oxygen Sensor is what's needed. Any suggestions will be greatly appreciated and thanks in advance. Tony. Link to comment Share on other sites More sharing options...
Yoshi Donating Members 136 Member For: 15y 10m 3d Gender: Male Location: Knox Posted 09/09/10 09:27 AM Share Posted 09/09/10 09:27 AM Maybe dirty throttle body, have you tried cleaning it with carby cleaner or throttle body cleaner? Link to comment Share on other sites More sharing options...
Davidxr6t03 Member 58 Member For: 14y 8m 11d Posted 09/09/10 09:35 AM Share Posted 09/09/10 09:35 AM I had a similar problem, so I replaced the Coils and Plugs(Purchased off ebay Cheap but all original) which fixed the rough idle. But I later replaced the oxygen censor which completely fixed my problem and was also purchased off ebay for around $70 and was fitted at a local mechanics for $50 because it was too tight to remove.I also did the throttle body clean which only made the car more responsive but for a 20 minute job, well worth it.Search the forum and all the how do's or diy's and they are all on the site with pic's.Best of luck.Dave. Link to comment Share on other sites More sharing options...
stillcruizin Member 7 Member For: 14y 9m 23d Posted 09/09/10 09:17 PM Author Share Posted 09/09/10 09:17 PM I had a similar problem, so I replaced the Coils and Plugs(Purchased off ebay Cheap but all original) which fixed the rough idle. But I later replaced the oxygen censor which completely fixed my problem and was also purchased off ebay for around $70 and was fitted at a local mechanics for $50 because it was too tight to remove.I also did the throttle body clean which only made the car more responsive but for a 20 minute job, well worth it.Search the forum and all the how do's or diy's and they are all on the site with pic's.Best of luck.Dave.Thanks Yoshi & Dave, did the coil/plugs replacement fix an idle problem or was it an acceleration problem?? Thanks, Tony. Link to comment Share on other sites More sharing options...
Davidxr6t03 Member 58 Member For: 14y 8m 11d Posted 10/09/10 10:51 AM Share Posted 10/09/10 10:51 AM Thanks Yoshi & Dave, did the coil/plugs replacement fix an idle problem or was it an acceleration problem?? Thanks, Tony.It fixed the Idle problem, I never had a problem with accelerating. Have a look at each Plug and Coil before you buy to check for problems. How many km's has your car done?Dave. Link to comment Share on other sites More sharing options...
stillcruizin Member 7 Member For: 14y 9m 23d Posted 11/09/10 12:44 AM Author Share Posted 11/09/10 12:44 AM It fixed the Idle problem, I never had a problem with accelerating. Have a look at each Plug and Coil before you buy to check for problems. How many km's has your car done?Dave.Around 95,000Km on the clock. Link to comment Share on other sites More sharing options...
Davidxr6t03 Member 58 Member For: 14y 8m 11d Posted 11/09/10 11:50 AM Share Posted 11/09/10 11:50 AM Around 95,000Km on the clock.With 95,000 I would be changing your plugs and coils anyway. Link to comment Share on other sites More sharing options...
stillcruizin Member 7 Member For: 14y 9m 23d Posted 11/09/10 07:19 PM Author Share Posted 11/09/10 07:19 PM With 95,000 I would be changing your plugs and coils anyway.Thanks for your help, I've only owned it for a couple of years, use it rarely and I suppose will have pick through the faults one at a time.Regards,Tony. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 3m 1d Gender: Male Location: Probably above atmospheric pressure Posted 11/09/10 11:47 PM Share Posted 11/09/10 11:47 PM I've had a rough idle for about 6 months now while stock. I've just gotten it tuned and still have the idle problem with new injectors.It was quite bad the other day after giving it a little on the highway so it was suggested it could be valve springs, but I like the idea of trying a new 02 sensor first going from those ebay prices! My car has just ticked over 100,000ks - May 2007 build. Link to comment Share on other sites More sharing options...
stillcruizin Member 7 Member For: 14y 9m 23d Posted 12/09/10 02:10 AM Author Share Posted 12/09/10 02:10 AM Yeah, I reckon starting with the cheaper components and moving up will be the way to go. As suggested, a throttle body clean, O2 sensor. If that fails, then plugs and coil. Link to comment Share on other sites More sharing options...
