  • Member For: 22y 1m 9d
hi I have a bf which has 360rwkw.it boosts normally most of the time but every now and then it will only boost to 5-10psi then only hold that.And also there is some times a rattling noise from turbo side during this problem.
the turbo has been ported and actuator changed, all bolts are tight
any help would be grately appreciated
https://www.fordxr6turbo.com/forum/topic/70373-boost-problems/
  • Member For: 15y 11m 16d
lol. Im sorting of having the same problem atm with my new ported turbo. Maybe they ported it too much and its bleeding boost. Or another prob may be the flapper arm is getting caught on something. On mine I found that the flapper arm had been bent slightly and it may of been rubbing on the exhaust joiner, so I grinded the joiner back a bit to give it full freedom of movement again.
its weird because when it happens and you back off and then accelerate again its fine.Had engine rebuilt and problem only started about 4000km after. Did you have to pull turbo back off to find problem?
  • Member For: 16y 17d
It sounds like you have a 9- 12 psi actuator. When the actuator opens the spring pressure isn't strong enough to close. Also with the bigger flap it takes more spring pressure to shut so when you back off it closes and the boost controller keep it shut unit it get to the correct pressure.
  • Member For: 15y 9m 17d
could be the cat moving slightly sometimes under hard acceleration then when you back off it goes back into place freeing up the exhaust, just an idea
