skidxr6t skids Donating Members 2,754 Member For: 12y 6m 1d Gender: Not Telling Posted 18/09/16 01:34 PM Share Posted 18/09/16 01:34 PM hey what did you do with your xcal? have you gone HP tuners as well? Link to comment https://www.fordxr6turbo.com/forum/topic/70315-my-baby-turned-300-at-last-pic-heavy/page/65/#findComment-1612629 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 7m 5d Gender: Male Location: Probably above atmospheric pressure Posted 18/09/16 01:38 PM Author Share Posted 18/09/16 01:38 PM Was wondering who would ask that question first! Still have it, unmarried, 4 unlocks left It won't be going back on my car - I used a secondary tune only once in the last six years to run 95. Now I own 2 jerries, 4 if I include the old metal one and the one the missus bought. The XCAL3 is basically capital that I need to liquidate so it can pay for something else, like a stronger fuel pump in the nearish future! 2 Link to comment https://www.fordxr6turbo.com/forum/topic/70315-my-baby-turned-300-at-last-pic-heavy/page/65/#findComment-1612630 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 9y 1m 10d Gender: Not Telling Location: Radioactive wasteland Posted 18/09/16 01:48 PM Share Posted 18/09/16 01:48 PM What sort of pump you chasing? Link to comment https://www.fordxr6turbo.com/forum/topic/70315-my-baby-turned-300-at-last-pic-heavy/page/65/#findComment-1612634 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 7m 5d Gender: Male Location: Probably above atmospheric pressure Posted 18/09/16 03:10 PM Author Share Posted 18/09/16 03:10 PM I'm not sure yet - it will only be an in tank solution, I'm not keen on a surge. I'm waiting on results of one someone else has already ordered. No big rush for this...the sooner the better because powerskids...but really it's just so I can get used to it before Racewars in early March 2017. I'll be entering the sprint as well as the drag racing/1000m top speed challenges. Have found the mega repair list, so here we go 6 Link to comment https://www.fordxr6turbo.com/forum/topic/70315-my-baby-turned-300-at-last-pic-heavy/page/65/#findComment-1612637 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 7m 5d Gender: Male Location: Probably above atmospheric pressure Posted 18/09/16 03:43 PM Author Share Posted 18/09/16 03:43 PM So Basically the engine had leaking gaskets on the timing cover and sump leaving a few drips of oil when parked - a bit unprofessional for a work car not to mention messing up my own driveway (or Kyle's for a few months hahaha cheers mate). It also had bulk exhaust leaks. They put a smoke machine on it to find them at first and it was leaking out all over the joint. Basically everything on the exhaust side! They machined the faces true and welded up the cracks in the dump and manifold, and fitted studs and washers to replace the exhaust manifold bolts. We discussed some options, in the end we went on a kit that came on advice from some turbo rotary racers that the mechanic deals with who used to have a similar issue with heat loosening nuts and bolts. I didn't get a name for exactly what he put on I'm afraid but the nuts look a bit special and they were in place nicely about 1000km later. This was mainly me asking for a way to reduce the amount of maintenance I have to do on the car. I'll give it back to him soon for a checkup at about 7,500km and see if they are still in place. Piccies! Cracked dump Welding it up Weld on the exhaust manifold - this wasn't even known to be cracked until it came off the car Shiny nuts, yeahhh boiiiii 6 Link to comment https://www.fordxr6turbo.com/forum/topic/70315-my-baby-turned-300-at-last-pic-heavy/page/65/#findComment-1612638 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 7m 5d Gender: Male Location: Probably above atmospheric pressure Posted 18/09/16 04:29 PM Author Share Posted 18/09/16 04:29 PM (edited) So the valve train is exposed in that last pic...here's why. DUN DUN DUNNNNNNNNNNNNNNNNN These were fine at 200,000km, with 100 to 200 being with stronger Crow valve springs. At some point between 200 and 300 thousand the hardening has worn off of the lobes and the lifters and rockers were looking a bit worse for wear too so we had to replace them. Tocchi came to the rescue in short order with a set of BF turbo cams and lifters/rockers he basically had laying around (because race car) so I passed them on and they slotted them in. While it was under the knife I also had them replace the timing chain with an atomic heavy duty one, why not. No pics so here's their video also new factory guides as mine once again had the end plastic missing ...and a set of Spool billet oil pump gears! Pic from their site: Quote This set replaces the standard gears which are powdered metal. Precision machined from 4340 billet steel. These gears have been proven under extremely harsh conditions & stress. Expand I've hit rev limiter a few times over the years and this will hopefully ward off a complete failure a bit longer! He said there were no dirty deposits of crap in the sump which was great to hear. They cleaned up the sump and timing cover for me real nice like. I almost bought a polished timing cover from Tocchi along with the other bits but they had already cleaned and painted mine up...plus it is only going to get dirty and stay dirty hahaha. Edited 18/09/16 04:33 PM by -Stever- 8 Link to comment https://www.fordxr6turbo.com/forum/topic/70315-my-baby-turned-300-at-last-pic-heavy/page/65/#findComment-1612639 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 7m 5d Gender: Male Location: Probably above atmospheric pressure Posted 18/09/16 04:59 PM Author Share Posted 18/09/16 04:59 PM As you can read in the invoice they also did some tidy up work in there such as securing my oil feed line with some nicer fittings (see pics of injector change earlier), adding an extra bracket to support the dump pipe so it's not just hanging off the turbo, replaced some ancillaries (water pump, power steering pump I supplied), fixed a stripped thread on the exhaust side... The damage all up was north of six grand (weeeeeeeeeeeeeeeeeeeeeee), probably closer to seven when I add in the parts I bought myself...it could have been even more if not for the help from Tocchi, I got lucky on that one so cheers dude! I have got my money's worth though, I've owned it for eight years and driven about 270,000 of the 312,000km myself Oh here's a pic I forgot to post earlier, stock versus Bosch 968s aka green tops 5 Link to comment https://www.fordxr6turbo.com/forum/topic/70315-my-baby-turned-300-at-last-pic-heavy/page/65/#findComment-1612640 Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 9y 2m 11d Posted 18/09/16 08:51 PM Share Posted 18/09/16 08:51 PM Alll that effort and no skid vid Poor form steve. Expecting some limiter bashing? 2 Link to comment https://www.fordxr6turbo.com/forum/topic/70315-my-baby-turned-300-at-last-pic-heavy/page/65/#findComment-1612642 Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 7m 5d Gender: Male Location: Perth Posted 18/09/16 10:12 PM Share Posted 18/09/16 10:12 PM I'm Always happy to help a nice person when I can Steve 2 Link to comment https://www.fordxr6turbo.com/forum/topic/70315-my-baby-turned-300-at-last-pic-heavy/page/65/#findComment-1612648 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 7m 5d Gender: Male Location: Probably above atmospheric pressure Posted 18/09/16 11:43 PM Author Share Posted 18/09/16 11:43 PM Hahaha yeah no skid vid...and I even have a bunch of spare tyres that the council won't collect as part of verge collection... 3 Link to comment https://www.fordxr6turbo.com/forum/topic/70315-my-baby-turned-300-at-last-pic-heavy/page/65/#findComment-1612659 Share on other sites More sharing options...
