masda74 To Loud Gold Donating Members 4,112 Member For: 13y 2m 12d Gender: Male Location: WA, Perth Posted 25/09/14 05:27 AM Share Posted 25/09/14 05:27 AM Okay I think I might be confused then. Is this for the automatic gear boxes? If so, then I have to say that I have a manual.I thought this was for dumping the oil from the engine. Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 11y 11m 17d Gender: Male Location: Frankston, 3199 Posted 25/09/14 05:33 AM Share Posted 25/09/14 05:33 AM Damn - I did warn that I was usually wrong :SI really have no idea why I had the tranny stuck in my head - you are correct 1 Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 18d Gender: Male Location: Probably above atmospheric pressure Posted 25/09/14 11:10 AM Author Share Posted 25/09/14 11:10 AM ololololololololGoogle fumoto drain valve and it's like the top link. $33 each plus delivery. The seller was unsure which thread pitch I needed, I had already looked on the vehicle compatibility list and like I wrote above it lists 2 Ford 4.0L Engines, but with slightly different thread pitches.Hard to see in the pic but the 109 has more turns per given distance, finer thread. Meshing them both against my existing sump plug I could see the 107 was the go. Plus just comparing threads by eye.Fixed a clunk in my window going down today...I'd tucked a plug behind the hard foam insert inside the door and it was obstructing the window glass as it moved down. Tore a small hole in the rubber liner stuff which I've just realised could be an issue in the wet, letting water into the plug area would not be good...grrr. At least It's easy to take the door card off, only takes about 2 minutes! But I'll leave it for another day. 1 Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 18d Gender: Male Location: Probably above atmospheric pressure Posted 10/11/14 11:42 AM Author Share Posted 10/11/14 11:42 AM I kept it under wraps well but I have upgraded to a secret prototype GTX turbo on the weekend, check it out. I can spool to 23PSI by 1550RPM in second just stalling it up in my driveway.BEAT THAT SUCKERSBig thanks to RaceTech. 5 Link to comment Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 10m 29d Gender: Male Location: Perth Posted 10/11/14 11:47 AM Share Posted 10/11/14 11:47 AM Allllll the boost! Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 2m 22d Gender: Male Location: Brisbane Posted 10/11/14 11:48 AM Share Posted 10/11/14 11:48 AM Fkn lol "big thanks to RaceTech" 1 Link to comment Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 11y 8m 17d Gender: Male Location: NOR Perth Posted 10/11/14 11:52 AM Share Posted 10/11/14 11:52 AM Smash the b00sst! 2 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 3m 16d Gender: Male Location: Perth Posted 10/11/14 11:52 AM Share Posted 10/11/14 11:52 AM That is FULLY sick BRO. You are the boost MASTER 1 Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 18d Gender: Male Location: Probably above atmospheric pressure Posted 10/11/14 12:42 PM Author Share Posted 10/11/14 12:42 PM (edited) Thanks fellas. It's unbelievable!If anyone else wants in on spool this mad I'll let you in on the secret for only $50 Hell I'll even post you the part...LOLAlso if you feel your own car is down on boost, it's because I am driving my car and it stole the air from your own airbox due to the maaaaddd spooooooooooool Edited 10/11/14 12:45 PM by -Stever- 3 Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 2m 22d Gender: Male Location: Brisbane Posted 10/11/14 11:04 PM Share Posted 10/11/14 11:04 PM Lol, but seriously that POS cost 50 bucks???? Link to comment Share on other sites More sharing options...
