Covesy Member 29 Member For: 15y 5m 18d Posted 01/09/10 07:38 AM Share Posted 01/09/10 07:38 AM Hi guysWhat actuator should I be getting in a bf f6?The mods are full exhaust, turbo flapper mod, ubp, 60lb injectors, fuel pump My tuner is recommending a 8lb but I'm not sure.Advise please Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 5m 21d Gender: Male Location: Townsville Posted 01/09/10 08:31 AM Share Posted 01/09/10 08:31 AM What your tuner recommends, if he says 8lb then go with that. Think 8lb are less prone to boost spiking depending on the boost levels? Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 8m 30d Gender: Male Location: Melbourne Posted 01/09/10 08:37 AM Share Posted 01/09/10 08:37 AM Isn't that a little light? Arn't the stock ones like 6? Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 9m 28d Gender: Male Location: central coast Posted 01/09/10 08:50 AM Share Posted 01/09/10 08:50 AM all depends what boost you want to run , they will hold more boost than there rated for ie. 8 may hold up too 14 psi , but you can't go backwards so if you get an 8 as far as I know you can't go lower than than 8psi boost. Link to comment Share on other sites More sharing options...
FPV6T UNDERCOAT CRUISER!!! Donating Members 1,655 Member For: 16y 1m 8d Gender: Male Location: brisbane Posted 01/09/10 08:53 AM Share Posted 01/09/10 08:53 AM if you have an 8psi actuator you can't run lower than 8psi boost.. Link to comment Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 7m 8d Gender: Male Location: Aspendale, Vic. Posted 01/09/10 09:21 AM Share Posted 01/09/10 09:21 AM depends what power your chasing, how hard you want to be on the motor, and fuel economy. Just get the 12 or 14lb.Im running 18lb. But im chasing 400-450rwkw (same motor as you). Link to comment Share on other sites More sharing options...
Covesy Member 29 Member For: 15y 5m 18d Posted 01/09/10 10:03 AM Author Share Posted 01/09/10 10:03 AM thanks guys,so if I go the 8psi will it be ok withh the higher end mods or do you think I will need to be upgraded later onwill the 12psi be ok with higher end mods alsothanks Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 9m 28d Gender: Male Location: central coast Posted 01/09/10 10:07 AM Share Posted 01/09/10 10:07 AM if your planning on running above 12psi yes go the 12 , I'm sure there's adjustable one out there contact Rapid site sponsor see what he's got Link to comment Share on other sites More sharing options...
Slash737 Member 107 Member For: 19y 11m 30d Gender: Male Location: western melbourne Posted 01/09/10 12:45 PM Share Posted 01/09/10 12:45 PM I have had the same mods done but with a stage 1 cooler and a 12lb actuator.car made 351 rwkw at 14 psi. I would recommend the 12lb actuator. Link to comment Share on other sites More sharing options...
