berzerker Donating Members 767 Member For: 16y 11m 6d Gender: Male Location: Brisbane Posted 31/08/10 01:56 PM Share Posted 31/08/10 01:56 PM Im currently waiting on all my audio gear to arrive from overseas.I asked for advice about a year ago, and still had the same system in mind.I ended up getting:Alpine cde-102eAlpine MRP-F300Alpine SWS-1223DFocal 570CA1 (I took Smickys advice with these and purchased from Northfield locally, thanks mate)Now I have gotten quotes (including all cabling) fromJB HIFI $480Northfield $450And called 6 auto electricians and none of them will do it..Does this sound like a fair price for the install? I though they were both a bit steep.If anyone here can do it for less in Brisbane pm me, or if you know of another good place thatll do it, let me know, otherwise ill more than likely go with Northfield. Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 6m 11d Gender: Male Location: adelaide hills- 'race air' central Posted 31/08/10 10:55 PM Share Posted 31/08/10 10:55 PM (edited) sounds reasonable to me... I did all the work myself and it takes ages.... Edited 31/08/10 10:56 PM by fordriver1 Link to comment Share on other sites More sharing options...
berzerker Donating Members 767 Member For: 16y 11m 6d Gender: Male Location: Brisbane Posted 31/08/10 11:33 PM Author Share Posted 31/08/10 11:33 PM That looks good, I can see why it took ages..I think I just want my amp mounted on the back of the seat, and sub in the middle at the back Link to comment Share on other sites More sharing options...
smicky Go Pies!!! Donating Members 2,852 Member For: 16y 9m 10d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 02/09/10 02:16 PM Share Posted 02/09/10 02:16 PM $$$ depends what u are expecting them to do..if u want sub box etc - that's why the elec WONT do it... they dont 'normally' know how!But as a 'general/basic' install - should about 25% to high to me... Link to comment Share on other sites More sharing options...
anwickes Member 47 Member For: 14y 3m 1d Posted 05/09/10 05:58 AM Share Posted 05/09/10 05:58 AM Do you guys know much about Rockford Fosgate Subwoofers?I'm looking at this one.... Rockford Fosgate 12 800 Watt Slim Subwoofer, Punch Series. [P3SD212 / P3SD412] - $399.00 : Car Audio Warehouse, Australia's best car audio deals,What sort of amp should I look at getting to run it and do I need one to run the sub and another to run the speakers? Link to comment Share on other sites More sharing options...
berzerker Donating Members 767 Member For: 16y 11m 6d Gender: Male Location: Brisbane Posted 05/09/10 07:19 AM Author Share Posted 05/09/10 07:19 AM (edited) Looks great except you could get it from here delivered for about $230Rockford Fosgate P3SD212 - 12" Car Subwoofer - Sonic ElectronixA 4 channel amp will run one set of speakers (fronts) and the subThe other rear speakers will run off the head unit. Edited 05/09/10 07:22 AM by berzerker Link to comment Share on other sites More sharing options...
anwickes Member 47 Member For: 14y 3m 1d Posted 05/09/10 07:38 AM Share Posted 05/09/10 07:38 AM So it's fairly standard to run the fronts off the amp instead of the rears?I'm liking the look of those focal speakers... Should I replace all 4 speakers? Also, do you think it's worth changing over the tweeters? Link to comment Share on other sites More sharing options...
Davidxr6t03 Member 58 Member For: 14y 5m 13d Posted 05/09/10 07:42 AM Share Posted 05/09/10 07:42 AM Looks great except you could get it from here delivered for about $230Rockford Fosgate P3SD212 - 12" Car Subwoofer - Sonic ElectronixA 4 channel amp will run one set of speakers (fronts) and the subThe other rear speakers will run off the head unit.If you buy the right Amp (2 ohm stable) then it will run your 2 fronts, 2 rears and 1 4ohm sub. It will generally run a little warmer than normal as per the load you are putting on the amp but a good quality amp will have no problem running it all. The only problem by setting it up this way is that you have no fade from Front to back which comes down to buying very similar sensitivity in the speakers specs to get a great sound in the car.Dave. Link to comment Share on other sites More sharing options...
berzerker Donating Members 767 Member For: 16y 11m 6d Gender: Male Location: Brisbane Posted 05/09/10 07:57 AM Author Share Posted 05/09/10 07:57 AM So it's fairly standard to run the fronts off the amp instead of the rears?I'm liking the look of those focal speakers... Should I replace all 4 speakers? Also, do you think it's worth changing over the tweeters?I would think so mate, as you sit in the front so you want the fronts to sound better.Those Focls that I bought are meant to be $249 in the Nothfield shop but they are incorrectly labelled at $229 on the website so they honoured that price.Northfield Car SoundThey still havent changed it so id snap up a pair of these before it gets changed. They in definitely in your budget too. Link to comment Share on other sites More sharing options...
berzerker Donating Members 767 Member For: 16y 11m 6d Gender: Male Location: Brisbane Posted 05/09/10 08:06 AM Author Share Posted 05/09/10 08:06 AM If you buy the right Amp (2 ohm stable) then it will run your 2 fronts, 2 rears and 1 4ohm sub. It will generally run a little warmer than normal as per the load you are putting on the amp but a good quality amp will have no problem running it all. The only problem by setting it up this way is that you have no fade from Front to back which comes down to buying very similar sensitivity in the speakers specs to get a great sound in the car.Dave.I didnt know this. Im just planning on buying a monoblock amp down the track. Link to comment Share on other sites More sharing options...
