blackxr6turbo Member 61 Member For: 16y 3m 9d Posted 31/08/10 01:34 AM Share Posted 31/08/10 01:34 AM hey guys - I am hoping someone may be able to help.I have had my car tuned for over and year now (no other mods), and just this week the following has started happening:- cruise control won't SET- when I turn my car off and take the key out, it keeps running until I touch the break- when I re-start the DSC light comes onOK, I just had it serviced and they reset the switches on the pedals. the weird thing is it only happens running the tune and is fine when flash to stock. Any help is greatly appreciated. Thanks. Link to comment https://www.fordxr6turbo.com/forum/topic/70271-cruise-and-dsc-light-on-when-flashed/ Share on other sites More sharing options...
Guest newl Guests Posted 31/08/10 01:41 AM Share Posted 31/08/10 01:41 AM I get the odd occasion where the cruise control will not set. Haven't been all that bothered by it enough to get it looked into by my tuner so it'll be interesting to see what comes of your query. Link to comment https://www.fordxr6turbo.com/forum/topic/70271-cruise-and-dsc-light-on-when-flashed/#findComment-1036276 Share on other sites More sharing options...
blackxr6turbo Member 61 Member For: 16y 3m 9d Posted 04/09/10 04:55 AM Author Share Posted 04/09/10 04:55 AM ok now it is happening almost all the time just running the standard tune, so makes me think there may be an issue with the cruise switch on the brakes (or clutch)? any tips on resetting this or other suggestions? Link to comment https://www.fordxr6turbo.com/forum/topic/70271-cruise-and-dsc-light-on-when-flashed/#findComment-1037395 Share on other sites More sharing options...
Guest newl Guests Posted 07/09/10 12:28 AM Share Posted 07/09/10 12:28 AM To follow up on this, I experienced it yesterday when coming home from my properties in the hills. Cruise wouldn't set again. Started thinking about what has an impact on the set functionality so I tapped the brake pedal and hit the Set button, no change. I lightly tapped the clutch and hit the Set button and it came on.Have a look at one or both of those switch assemblies. Might need an adjustment (if it is possible..I've not assumed the astronaut position yet to find out). Link to comment https://www.fordxr6turbo.com/forum/topic/70271-cruise-and-dsc-light-on-when-flashed/#findComment-1038022 Share on other sites More sharing options...
blackxr6turbo Member 61 Member For: 16y 3m 9d Posted 07/09/10 09:42 AM Author Share Posted 07/09/10 09:42 AM yeah it goes to the dealers tomorrow, I feed back the results. Link to comment https://www.fordxr6turbo.com/forum/topic/70271-cruise-and-dsc-light-on-when-flashed/#findComment-1038158 Share on other sites More sharing options...
Vevapower Waiting for the 1st N/A 12! Donating Members 2,533 Member For: 17y 2m 23d Gender: Male Location: Sydney Posted 07/09/10 09:53 AM Share Posted 07/09/10 09:53 AM Do you have an XCAL3? If so you can read all the DTC codes and find out exactlly what's happening if a error code is logged!The Xcal3 can even clear these DTC codes and turn off all the warning lights as well! Link to comment https://www.fordxr6turbo.com/forum/topic/70271-cruise-and-dsc-light-on-when-flashed/#findComment-1038160 Share on other sites More sharing options...
