  • Banned
  • Banned
  • Member For: 14y 7m 9d
  On 25/09/2010 at 9:20 AM, rab said:
played with mine today...was so cold there was a god damn polar bear knocking on the side window !
wish I had never made that statement ! its been fuct since ! wife thought it was working and as I dont srive it that much I sayed ok... drove it tonight in pissing rain and had a sauna inside the car and rain was so hard I had to endure the steamy windows... so, 1000klms on the brand new car and HIM appears to be the issue... did any you guys get it done while you wait ? SMALL JOB ? pre booked to be ready in stock ??
  • Replies 32
  • Banned
  • Banned
update... was in ford and tested... was freezing and didnt act up ! won't change it till they see it doing it or fault code shows... tossers... anyway, going in for its 3k service in a fortnight and guy said they will change it over..thing is, it has been perfect since and wife thinks I am mad as a box of frogs !...was set at 22 all day today(done 400klms) and had it on low fan setting, car was lovely ! so, we'll see how it goes over the next week or two !
  • Member For: 18y 5m 29d
  On 04/09/2010 at 1:24 PM, Rogue01 said:
Think the recall code was R1005. HMI module. Got mine done, all sweet now. If you own an FG and havent moved or bought it second hand, you shouldve got a recall letter from Ford.
This is what I did, Ford confirmed that R1005 is the recall number, so I'm sure that if you quote this you should be right!
  • Member For: 16y 7m 17d
My F6 did it the day I picked it up (May 2010).. and got home :(
They bled the air con system and it seemed to fix the problem until a few weeks ago, its there again - Air Con not working, it was working fine for the 1st hour of a 2 hour trip, then started to get warmer and warmer. My air con pipe from condenser to firewall gets COVERED in ice, not just a bit - FULLY FROSTED UP
Thanks guys, I will quote the above and get it sorted..
They didnt mention ANY recall or HIM problems
  • Member For: 17y 10m 15d
Ive just noticed last week that when use the climate control I get a clicking noise for about 1 minute from behind the dash somewhere it then stops , would this be related to the HIM module ? . Its an oct 09 build XRT .
adam
  • 4 weeks later...
  • Member For: 14y 5m 12d
My 2009 XR6T packed it in 2 days ago. Only the drivers side of the car was blowing air at the set temperature - hot or cold. The passenger side just blew what ever the ambient temp air was...
Ford fixed it under warranty and all is well - hopefully for a while!
  • 4 weeks later...
  • Member For: 14y 6m 10d
I bought a xr50t ute and the aircon didnt work by the time I got it home,
I took it back and they changed some O ring on the compressor and it worked again,for about 3 hrs and then it just blew hot air.
Ive taken it back again on tuesday and they still havent fixed it,they rang today and said it wont be ready till next tuesday cause they are waiting for a part to come in and they asked if I could leave it there cause they have taken the dash out.
Not happy!
should I hit them up for some freebies?
  • 4 months later...
  • Member For: 14y 10m
wot year models did this fault affect, ive got a late 2010 and ive got air issues, sounds very similar but according to ford mine isnt affected by this recall?
