Knocking Noise - Abs Unit?
  • Member For: 16y 3m 21d
G'day everyone
Since I have owned my T it experiences a knocking sound after startup.
Series of events:
Startup, drive to almost exactly 10km/h (every time), then it goes knocka-knocka-knocka-knocka-knocka and then no more noise until next startup.
Braking performance is normal. I was told that it was the abs unit - because the discs and pads were worn out - but after I fitted new discs and pads the noise came back. I got one start and take off without any noise - woohoo!
Any ideas guys?
Cheers,
Chris
  • Member For: 19y 9m 1d
Mine does the same...you start it...then put it in drive and about 5 seconds later you hear that knocking noise for about 3 seconds and then nothing everything is normal...mine does this without fail every time...I have always wondered wether this is normal...
here's a possibility - when I was dismantling my front end (for some nice new nolathane bushes to go in) - I noticed that the brake line coming through the bodywork on the passengers side had chopped through its grommet. I'll fix this and see if it fixes the problem once I get the front end back together.
  • Go Pies!!!
  • Member For: 17y 3d
ABS self test..
Next service just get them to check the sensors are ok... I had one a bit flakey on the startup test thingy... but once the car had moved and hit the brakes it was fine... Dealers wasnt sure why the 'test' wasnt 100% but the ABS sensor and rest of the system was fine!
They just replaced it anyays.. :)
Edited by smicky
