CAM860 Donating Members 96 Member For: 15y 9m 9d Gender: Male Location: Toowoomba Posted 28/08/10 10:31 AM Share Posted 28/08/10 10:31 AM check the bolts around the centre of the turbo, you will need to take the heat shield off for this and it might be quite difficult to get the lower ones, mine had a ticking sort of sound for a while and then it ended up being a sound like a tractor, and I pulled the turbo off and found one of these little bolts had worked itself loose and fell out eventually.probably not the problem, but worth a look anyway as its a common problem. Link to comment Share on other sites More sharing options...
