Sard New Member 23 Member For: 16y 6m 15d Posted 18/08/10 12:40 PM Share Posted 18/08/10 12:40 PM Hi guys,Looks like this problem has been around awhile but I have not seen anyone have the proper answer. At about 100k my steering wheel shudders terrible. Not the same all of the time. It is not brakes, wheel balance or any obvious suspension stuff. ??? anyone Link to comment https://www.fordxr6turbo.com/forum/topic/70057-front-end-shudder/ Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 8m 6d Gender: Male Location: Townsville Posted 18/08/10 03:49 PM Share Posted 18/08/10 03:49 PM Do you have any play in the steering? Have you rotated the tyres? Have you had the tyres balanced again recently? Have you had a wheel alignment recently?Rule out as many of the possibilities then the list gets smaller. Link to comment https://www.fordxr6turbo.com/forum/topic/70057-front-end-shudder/#findComment-1033643 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 3m 22d Gender: Male Location: Christchurch, New Zealand Posted 18/08/10 06:50 PM Share Posted 18/08/10 06:50 PM I have heard something about the alignment needing a little toe in so when you get to highway speeds the toe pulls to a neutral position because of the way the front end is setup. I dont know how true this is just what ive heard, someone might be able to shed some light on this. Link to comment https://www.fordxr6turbo.com/forum/topic/70057-front-end-shudder/#findComment-1033660 Share on other sites More sharing options...
Sard New Member 23 Member For: 16y 6m 15d Posted 21/08/10 02:09 AM Author Share Posted 21/08/10 02:09 AM I have eliminated most of the regular things. I have new tyres, wheel alignment, wheel balanced and and rotated. Steering is OK and no obvious suspension issues. Pretty sure it is not brakes because it happens when I am not using the brakes. Link to comment https://www.fordxr6turbo.com/forum/topic/70057-front-end-shudder/#findComment-1034088 Share on other sites More sharing options...
Guest XR09 Guests Posted 21/08/10 04:28 AM Share Posted 21/08/10 04:28 AM If you have done all the usual then have a look at the condition of the bushes, and make sure it still has its shimms in place. Steering pump ?? Link to comment https://www.fordxr6turbo.com/forum/topic/70057-front-end-shudder/#findComment-1034105 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 2m 26d Gender: Male Location: Sydney Posted 21/08/10 08:10 AM Share Posted 21/08/10 08:10 AM I would look at getting a On Car Balance (OCB) as it will balance the whole wheel and rotor assembly.It will atleast give you a better idea on what is causing it. Front suspension is not rocket science, so a propper suspension place should sort it out quickly.Do not go to a tyre place as they are limited by skill and ability. Link to comment https://www.fordxr6turbo.com/forum/topic/70057-front-end-shudder/#findComment-1034165 Share on other sites More sharing options...
