  • Member For: 13y 10m 27d
  On 25/10/2011 at 11:22 PM, DEDLYWEPN said:
WA g6et, which shop did you take yours to? I foolishly had mine done at pedders and it has creaked in the right rear ever since (which my dealer says is "a body creak"!! even though it wasn't there until after the alignment), so I'm looking for a good shop to take it to. Have considered Wilkinsons or Wheels World, but just wondered where you went.
Also, what did you pay for the alterations? (the rear bushes and changes to the front etc)
Cheers,
Josh
Go to WA suspension in Ossie Park, they know their stuff very well. I have used Wilkinsons in the past and have found them lacking in customer service.
Cost will depend on what you need on the front. They aren't the cheapest but certainly one of the best. If you ask they can help with a loan car for a few hours as well.
The bush for the rear was a couple of hundred and the front depending on if they modify the bolts and bushes or use a rachet style kit will be around $300+ but add labour and alignment it will add up to around $800+. Might seem a lot, probably is given Ford should have designed a car with some adjustment, but it will definately improve tyre wear and help with some better traction on the rear at the same time.
