AIM-300 SUPERLAP 2011 Member 158 Member For: 17y 8m 4d Gender: Male Location: townsville Posted 04/12/10 09:11 AM Author Share Posted 04/12/10 09:11 AM sick erko, think a set of ce28n's in black all time attacked up with a bionic stripe instead of red would look sickthink below with a bionic blue stripe Link to comment Share on other sites More sharing options...
Sprjenkins Member 52 Member For: 16y 4m 7d Gender: Male Location: Melbourne Posted 20/01/11 01:49 PM Share Posted 20/01/11 01:49 PM SOunds like a great build up.Make sure you post heaps of pics of the path you are taking to keep us up to date.Hopefully you come up with something along these lines. All the best HAHA, took out the boat anchor and then ran 9 seconds a lap slower than a V8 Supercar, massive massive fail! Link to comment Share on other sites More sharing options...
Sprjenkins Member 52 Member For: 16y 4m 7d Gender: Male Location: Melbourne Posted 20/01/11 02:04 PM Share Posted 20/01/11 02:04 PM to be honest I have never driven on the tiens in a falcon so id be lying if I said they were better of worse. I do know that recently pedders completely redesigned their dampner side of the coilover to help with bottoming so weather that has anything to do with other peoples issues then yeah could explain a bit. honestly the pedders setup was the best mod I ever did to the ute. it changed it from a sloppy commuter to something that could be driven aggressivly and perdictably. if anything it was a killjoy because it was so easy to drive fast that it lost its scaryness if you know what I mean. th main reason I went with the pedders over the tiens was the base height adjustment with out changing the spring rate. suspension is a very simple thing. setup is where the difference is made. I highly doubt any difference in time was made up by the change from pedders to tien could not have been made up by a setup change and some tweaking.adamI had Tein coilovers on my BA Sedan, with the higher performance spring rate and to tell you the truth they were disapointing. Also they are height adjustable but what use is that if when you change suspension height your wheel alignment goes out. Next time I'll probably go for Bilstein springs and shocks.Your suspension pickup points must remain the same but that doesn't mean you can't get custom control arms made up. V8 supercars run -6 degrees camber on the front and you'll never get close to that without changing you control arms or suspension pick up points.Brembo calipers of a Super Pursuit will make a massive difference over your standard brakes but they are still road car calipers. You would be much better off getting a brand new set of Brembo monoblocks designed for a Porsche Cup Car for around $600 new (Porsche 996, 997 are more expensive if I remember correctly). You will need to have custom brackets made which will set you back $600 for the pair but your brakes will be so much better for it.Cheers Joel Link to comment Share on other sites More sharing options...
SteveJH Member 52 Member For: 14y 10m 11d Gender: Male Location: Newcastle, NSW Posted 31/01/11 12:17 PM Share Posted 31/01/11 12:17 PM HAHA, took out the boat anchor and then ran 9 seconds a lap slower than a V8 Supercar, massive massive fail!It was running road tires rather then V8 Supercar spec slicks, plus fairly sure the engine only went into the car something like a day or two before time attack started.Also, look at that thing kick out as he tries to accelerate out of the corner.. Link to comment Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 5m 3d Gender: Male Location: Sydney Posted 06/02/11 11:52 PM Share Posted 06/02/11 11:52 PM Any more progress on this car?You doing any track days in NSW before Superlap? Link to comment Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 5m 3d Gender: Male Location: Sydney Posted 10/03/11 08:41 AM Share Posted 10/03/11 08:41 AM http://www.worldtimeattack.com/index.php/fernandez-plans-revealed-for-wtac-2011/ Link to comment Share on other sites More sharing options...
AIM-300 SUPERLAP 2011 Member 158 Member For: 17y 8m 4d Gender: Male Location: townsville Posted 10/03/11 11:39 AM Author Share Posted 10/03/11 11:39 AM oh mutha fukker its on like donkey konghttp://www.worldtimeattack.com/index.php/fernandez-plans-revealed-for-wtac-2011/yeah slow progress til now. settled in to my job so things will be progressing along rather rapidly. organising the materials for the undertray next swing off. the new exhaust will be fabbed up and back looking at brake options. basicly looking back at regs in regards to how muuch interior I can remove aswell as what aero I can run in regards to class rules. recently I have been really just settling into the new job, playing with allignment and tyres, and getting the existing issues I had with the car settled. money had been tight over christmas so basicly only had the time to fab up the new battery box and remount it. fix the cai and start talking tyres with my brother (toyo). hoping to have the hard cover finalised and ordered in the next fortnight aswell as have my brake choice done to be ordered the following fortnight. is interesting jose's choice of car to race... Link to comment Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 5m 3d Gender: Male Location: Sydney Posted 15/03/11 09:53 AM Share Posted 15/03/11 09:53 AM (edited) Some of these parts could save hundreds of kg!http://www.carbonart...p/products/ford Edited 08/05/11 09:42 AM by RHR Link to comment Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 5m 3d Gender: Male Location: Sydney Posted 08/05/11 08:41 AM Share Posted 08/05/11 08:41 AM http://www.worldtimeattack.com/index.php/fernandez-update-xr6-ute-pro-class/ Link to comment Share on other sites More sharing options...
Rosie Member 361 Member For: 17y 7m 20d Posted 09/05/11 09:05 PM Share Posted 09/05/11 09:05 PM You didn't happen to notice the 'unusual' configuration of his rear Tyre setup did you?- It will be interesting to see what the organisers have to say about it! Link to comment Share on other sites More sharing options...
