Running Rich
xcopbf
  • FLY-FPV
  • Member For: 15y 7m 3d
Yeah when my fuel pressure was at 90psi I was using heaps more fuel and you could smell it through the exhaust and and was dripping un burnt fuel out the exhaust as well lol it sucked but I put a fuel pressure gauge in front of the fuel rail and found out the pressure was way to high so I started by changing the fuel pressure reg and no change then decided to take the walbro in tank out and put the stock one back in and bingo all fixed back to around 60 psi on idle
  • Member For: 19y 2m 14d
Thanks for the info guys it all helps.
Ratter have you had other walbro pumped vehicles output approx 68psi and if you have were there any issues setting up dekka 60s to suit this psi or does the pressure plain and simply have to come back down to oem specs?
Cheers
  • Member For: 19y 7m 24d
I'm surprised you guys are seeing this much pressure. You normally run 4 bar base at idle and under manifold vacuum at idle it is actually a fair bit lower again. 61 at idle with the vacuum line connected to the reg is waaaay too high!
  • Member For: 18y 9m 4d
Cheers
We do not do fuel pressure checks on every car, but some of the ones we have, have seen a pressure increase with a walbro fitted, normally the ecu will compensate to a certain point, but there are ways to adjust things so the ecu does not need to compensate out of it ordinary range.
If it was at oem specs, the original tune will be closer for fuel control at lower ranges
Edited by ratter
  • Member For: 13y 9m 1d
I have 60lb dekas with stock in-tank pump and had a surge and 044 fitted later, afrs ended up a little fat, my tuner trimmed them up. His words were like, it was rich in the low rpm and cold running areas, not totally sure what it all meant. Much better now, uses less fuel and exhaust tips stay cleaner.
