  • Member For: 18y 11m 9d
your obviously going to the wrong mechanic if they charge you $800 labour to do the job.
Ford CV assembly's are around $850ish each and normally approx an hour a side to do, ford ones are better than most the replacement items except for the big dollar ones
  • Forged Member
  • Member For: 18y 2m 29d
Don't forget to buy the new crush washer/nut for the end of the axle (hub end) as these should really only be a one use only part.
  • Member For: 14y 9m 9d
dude its probably the diff.. I did mine last week,
if it were cv u probably be able 2 drive the other wheel, coz the diff will be able to engage
pretty sure that's what the grinding noise is.. the pins on the diff wont engage
  • Member For: 16y 11m 29d
  On 02/08/2010 at 10:17 AM, ratter said:
they will not drive with a broken shaft or CV, they are not a locker
Damn it shows what I know :beerchug:
