sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 7m 12d Gender: Male Location: Far north queensland Posted 31/07/10 02:11 AM Share Posted 31/07/10 02:11 AM Looking to get some valve springs in soon but not looking to chase massive boost. Will probably only be 16psi, my valve springs are holding on ok but I'm thinking of getting them done anyway.Question is do I go for the crow or atomic ones? Link to comment https://www.fordxr6turbo.com/forum/topic/69733-valve-springs/ Share on other sites More sharing options...
possum Donating Members 553 Member For: 16y 15d Gender: Male Posted 31/07/10 02:28 AM Share Posted 31/07/10 02:28 AM Brad from atomic would have to be one of the nicest guys I have ever dealt with! so my vote goes to atomic Link to comment https://www.fordxr6turbo.com/forum/topic/69733-valve-springs/#findComment-1028972 Share on other sites More sharing options...
Molloy Member 216 Member For: 17y 3m 19d Gender: Male Location: Taree Posted 31/07/10 04:21 AM Share Posted 31/07/10 04:21 AM Atomic FTW Link to comment https://www.fordxr6turbo.com/forum/topic/69733-valve-springs/#findComment-1028983 Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 9m 20d Gender: Male Location: Broady, Melbourne Posted 31/07/10 04:28 AM Share Posted 31/07/10 04:28 AM Same springs mate. Link to comment https://www.fordxr6turbo.com/forum/topic/69733-valve-springs/#findComment-1028984 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 7m 12d Gender: Male Location: Far north queensland Posted 31/07/10 06:27 AM Author Share Posted 31/07/10 06:27 AM thanks straughsberry Link to comment https://www.fordxr6turbo.com/forum/topic/69733-valve-springs/#findComment-1029009 Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 5m 14d Gender: Male Location: Sydney Posted 31/07/10 06:29 AM Share Posted 31/07/10 06:29 AM My BF F6 will be changed over to Atomic when Jim gets backs from O/S. The Nizpro's currently installed don't hold up at higher rpm under load.I've seen a number of 450+ rwkw cars in the last 6 months with Atomic, and they do the job well.I haven't had anything to do with Crow, so can't comment.Brian Link to comment https://www.fordxr6turbo.com/forum/topic/69733-valve-springs/#findComment-1029011 Share on other sites More sharing options...
Molloy Member 216 Member For: 17y 3m 19d Gender: Male Location: Taree Posted 31/07/10 06:34 AM Share Posted 31/07/10 06:34 AM On 31/07/2010 at 6:29 AM, bcl said: My BF F6 will be changed over to Atomic when Jim gets backs from O/S. The Nizpro's currently installed don't hold up at higher rpm under load.I've seen a number of 450+ rwkw cars in the last 6 months with Atomic, and they do the job well.I haven't had anything to do with Crow, so can't comment.BrianAre these the Nizpro cobra springs?? Link to comment https://www.fordxr6turbo.com/forum/topic/69733-valve-springs/#findComment-1029013 Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 5m 14d Gender: Male Location: Sydney Posted 31/07/10 06:43 AM Share Posted 31/07/10 06:43 AM Yes. I'm pushing over 450rwkw with a modified turbo & upgraded ZF. Link to comment https://www.fordxr6turbo.com/forum/topic/69733-valve-springs/#findComment-1029017 Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 9m 20d Gender: Male Location: Broady, Melbourne Posted 31/07/10 06:46 AM Share Posted 31/07/10 06:46 AM On 31/07/2010 at 6:27 AM, sideways82 said: thanks straughsberry NP mate.Just to clarify what I meant, they are the same quality ovate alpha behive spring. Probably the best off the shelf spring available for our cars. Standard seat pressure at installed height is 95lb from memory. With a shim, they can be taken to 110+lbs to handle 40psi or more. As others have said and as I've experienced myself, Brad has always got time to help you out and point you in the right direction. Atomic have many excellent products and easily the most extensive range for our cars. I'll be using many of Atomic's products in my big-banger including cams, vernier gears, oil pump, race girdle, stud kit and timing chain. Link to comment https://www.fordxr6turbo.com/forum/topic/69733-valve-springs/#findComment-1029019 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 7m 12d Gender: Male Location: Far north queensland Posted 31/07/10 09:52 AM Author Share Posted 31/07/10 09:52 AM yeah I downloaded their catalogue, very impressive range. Link to comment https://www.fordxr6turbo.com/forum/topic/69733-valve-springs/#findComment-1029097 Share on other sites More sharing options...
