Camber Kits..
MiKa
  • Member For: 18y 6m 8d
In need of a camber kit fitted to the rear in Melbourne... Anyone know where and how much, cbf looking for a decent place, would rather recommendations..
Came back from Tassie today, get picked up in the T and 10 mins after being picked up, we get a flat... Take the wheel off and the whole inside is chewed up...
Cheers Mike..
  • Member For: 17y 9m 3d
I wasn't aware the rears had a problems with camber on the falcon, only thought it was the front.
Dropped the car off to get some new rubber.. asked the guy about camber kits and he didnt seem to think that BA's have em for the rear? He said you can adjust them as is, but as for extra 'shims' or kits he seemed a bit lost... Gettin a wheel alignment anyways...
Just what I wanted on my weekend back in Melb, wasting time and money when I could be doing alot of other sh*t!!
Dillz, I should have got a pic of the shagged rear, but it was farked on the inside, my cousin got stabbed lol... The drivers side rear was farked but the other wasnt as bad but is headin the same way? Could it be shocks are gone or anything else? The cars not that low...
Might be something else I think, like a bad puncture or something. Cause if the camber was off both rears would be effected yeah?
Nah the tyre wore out till it finally gave up and deflated.. The other rear has the same wear but not as bad... I dun understand??
  • Member For: 16y 8m 8d
There is limited adjustment for camber and toe on the rear of XR's. If too much negative camber can't be adjusted out then you need to fit some off-set inner upper control arm bushes. Good for about 1 degree of adjustment.
  • Member For: 19y 9m 27d
MIne is the same. Chewed the left rear inside all the way to the steel.
Camber kit from Peddars is $445 fitted.
Had another alignment done a few weeks ago (without the kit) as I just got a set of Falkens, have done about 2000kmand the wear looks ok at this stage.
My wait another 2-3000km and re-measure. If the wear is bad I'll get the rear camber kit installed.
$445.00 fitted?!
What did they fit for $445.00? The off-set upper inner control arm bushes are $75.00 a set (the kit has two bushes, you can't buy a single one if you only want one side of the car done.) and took me about an hour to fit one side (all I needed to fix up the camber problem).
PS: I have one brand new upper inner control arm bush gathering dust if anyone wants it - $40 delivered anywhere in Oz.
Edited by xr6greg
