  • Member For: 15y 7m 4d
303rwkw in a BA Phoon @17psi
X-Force Dual 2.5" Exhaust, from 4" Dump 5" Cat.
Plazmaman Cooler
Nizpro Re-drilled Injectors
Nizpro Actuator and Wastegate Mod
Walbro In-tank Pump
Nizpro Custom Tune and Xcal1 <- :3gears:
Rapid Hot & Cold Side piping to go on car very soon, sitting in my lounge room, as well as Under Battery CAI.
Then I do believe a re-tune is in order, to make the most of it :bum:
https://www.fordxr6turbo.com/forum/topic/69724-303rwkw/
  • Replies 22
Was running lean, then installed the Walbro and haven't had re-tuned since. Was going to and then f$!%#n SCT kind of ruined that. Putting the pipes, CAI on, possibly a surge tank if required, then aim a bit higher, hopefully around the 340 .
Oh, and wasn't re-tuned after the actuator and wastegate either, Nizpro assured me it would be fine. :3gears:
https://www.fordxr6turbo.com/forum/topic/69724-303rwkw/#findComment-1028842
  • Member For: 15y 6m 27d
yeah I dont understand why your running 17psi?!?! you should be able to safe tune it too 14ish an get more power out of you car with those mods...
sorry I didnt reload page before I posted haha..
but stll very high boost?!
Edited by KeithTheBricklayer
https://www.fordxr6turbo.com/forum/topic/69724-303rwkw/#findComment-1028846
  • UNDERCOAT CRUISER!!!
  • Member For: 16y 5m 1d
  On 30/07/2010 at 8:45 AM, bradles024 said:
No valve springs, thought Phoon motor could handle it.
nah,not the BA motors I did mine for piece of mind,also I'm getting 295rwkw out of my 10psi tune,17psi seems a bit excessive. :3gears:
good work otherwise.. :bum:
https://www.fordxr6turbo.com/forum/topic/69724-303rwkw/#findComment-1028851
