Gettin_sideways New Member 14 Member For: 15y 10d Gender: Male Location: Canberra Posted 26/07/10 07:49 AM Share Posted 26/07/10 07:49 AM Ok my drivers side seat is loose as and leans forward under mild/heavy braking as much as an inch or 2. I tried looking under the seat thinking one of the bolts holding it on was loose but they all seemed firmly in place. Problem seems to be the adjusting brackets as the passengers seat is solid as and doesnt have them. I need to get it fixed asap as im heading to the track this thursday. Has anyone had this problem before? quick fix tips? Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/69629-wobbly-drivers-seat/ Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 5m 10d Gender: Male Location: Christchurch, New Zealand Posted 27/07/10 05:35 AM Share Posted 27/07/10 05:35 AM Check the bolts that hold the frame to the chassis. Link to comment https://www.fordxr6turbo.com/forum/topic/69629-wobbly-drivers-seat/#findComment-1027978 Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 20y 1m 10d Posted 18/08/10 05:07 AM Share Posted 18/08/10 05:07 AM How did you with the wobbly seat? How did you fix it? Link to comment https://www.fordxr6turbo.com/forum/topic/69629-wobbly-drivers-seat/#findComment-1033463 Share on other sites More sharing options...
4DZILR Donating Members 713 Member For: 15y 4m 24d Gender: Male Location: Sydney - Brighton Le Sands Posted 18/08/10 06:33 AM Share Posted 18/08/10 06:33 AM You really gotta pull your seat apart guys.. Had this issue..It was the actual rod which was spun too many times which causes the lumber(for your bum) support to move around.. Link to comment https://www.fordxr6turbo.com/forum/topic/69629-wobbly-drivers-seat/#findComment-1033481 Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 20y 1m 10d Posted 19/08/10 01:41 AM Share Posted 19/08/10 01:41 AM Hmmm...I think im having the same problem so you pulled your seat appart...did you have to replace anything etc... Link to comment https://www.fordxr6turbo.com/forum/topic/69629-wobbly-drivers-seat/#findComment-1033711 Share on other sites More sharing options...
Gettin_sideways New Member 14 Member For: 15y 10d Gender: Male Location: Canberra Posted 09/10/10 11:34 PM Author Share Posted 09/10/10 11:34 PM Hey yeah I finally found the problem. Underneath the seat there are 4 screws that attach the seat to the rails. The frame around the front 2 screws had cracked and warped, allowing the screws to bend and flex. In the end I pulled the seat out of the car, deattached the seat frame (easy as piss) and welded the cracks back together. It fixed the problem right up and the seat has been solid as ever since. Pretty easy to fix, and alot cheaper then buying a new chair. Link to comment https://www.fordxr6turbo.com/forum/topic/69629-wobbly-drivers-seat/#findComment-1046509 Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 7m 19d Gender: Male Location: left right out Posted 10/10/10 12:05 AM Share Posted 10/10/10 12:05 AM Good fix, was this a b series or fg? Link to comment https://www.fordxr6turbo.com/forum/topic/69629-wobbly-drivers-seat/#findComment-1046514 Share on other sites More sharing options...
Gettin_sideways New Member 14 Member For: 15y 10d Gender: Male Location: Canberra Posted 11/10/10 02:31 AM Author Share Posted 11/10/10 02:31 AM 2003 BA series Link to comment https://www.fordxr6turbo.com/forum/topic/69629-wobbly-drivers-seat/#findComment-1046765 Share on other sites More sharing options...
