mercules Banned 22 Member For: 14y 1m 30d Gender: Male Posted 24/12/10 12:24 AM Share Posted 24/12/10 12:24 AM hey guys I recently had a filter installed on my typhoon altho I like zip ties I think theres a time and place to I have used spark plug wire seperators im still looking for sum more though as the 1s I used are cheap plastic 1s it doesnt hold the line as tight as I would like im looking into sum billet 1s atm but cant seem to buy them ind I will keep posted on how it pans out but heres sum pics of plastics installed cheers Link to comment Share on other sites More sharing options...
Skidude Member 115 Member For: 15y 5m 3d Gender: Male Location: Penrith, NSW Posted 29/12/10 10:33 AM Share Posted 29/12/10 10:33 AM Guys, how tight should I nip up the oil pressure switch side against the copper washer and banjo ?I'm worried about crushing the banjo if I over tighten. Link to comment Share on other sites More sharing options...
mrmackie Donating Members 67 Member For: 17y 4m 24d Gender: Male Location: Perth - CBD Posted 29/12/10 12:37 PM Share Posted 29/12/10 12:37 PM (edited) Short of trying to get a torque rench in there, a firm nip up should be fine. Make sure you have sanded the copper washers with some fine wet-n-dry on a FLAT SURFACE (Glass is the best for this). I also found doing this to the 2 aluminum washers on the filter help it to seal as mine leaked on both ends of the filter, even though I thought I tightened it up properly. Edited 11/01/11 01:22 AM by RHR No need to quote above post. USE FAST REPLY Link to comment Share on other sites More sharing options...
Rudiger All round good guy! Lifetime Members 1,122 Member For: 16y 9m 2d Gender: Male Location: Greenvale, Victoria Posted 29/12/10 01:02 PM Share Posted 29/12/10 01:02 PM Can I ask a dum question? Whats the benifit of this? Link to comment Share on other sites More sharing options...
Skidude Member 115 Member For: 15y 5m 3d Gender: Male Location: Penrith, NSW Posted 29/12/10 07:59 PM Share Posted 29/12/10 07:59 PM Short of trying to get a torque rench in there, a firm nip up should be fine. Make sure you have sanded the copper washers with some fine wet-n-dry on a FLAT SURFACE (Glass is the best for this). I also found doing this to the 2 aluminum washers on the filter help it to seal as mine leaked on both ends of the filter, even though I thought I tightened it up properly.Do you mean that you sand the washers if re-using the old ones ?I didn't sand them as I had new ones for which fraud charged me my left testicle. Link to comment Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 3m 2d Gender: Male Location: left right out Posted 30/12/10 12:44 AM Share Posted 30/12/10 12:44 AM I just put a thin smear of gasket sealant either side of each washer, mild tension to tighten and no leaks. Link to comment Share on other sites More sharing options...
Skidude Member 115 Member For: 15y 5m 3d Gender: Male Location: Penrith, NSW Posted 10/01/11 10:59 AM Share Posted 10/01/11 10:59 AM (edited) hey guys I recently had a filter installed on my typhoon altho I like zip ties I think theres a time and place to I have used spark plug wire seperators im still looking for sum more though as the 1s I used are cheap plastic 1s it doesnt hold the line as tight as I would like im looking into sum billet 1s atm but cant seem to buy them ind I will keep posted on how it pans out but heres sum pics of plastics installed cheersI have bought these from Earls.http://www.earls.com.au/files/49ff9a6ab4b96-BILLETLINECLAMPSSEPARATORS.pdfThe return pipe is 12mm. So I've gone for the 1/2 inch clamp. I've put some high temp electrical tape on the pipe to make it up to 1/2 inch diameter.They're not cheap either - $47 for two in blue. Edited 10/01/11 11:05 AM by Skidude Link to comment Share on other sites More sharing options...
Skidude Member 115 Member For: 15y 5m 3d Gender: Male Location: Penrith, NSW Posted 11/01/11 06:55 AM Share Posted 11/01/11 06:55 AM (edited) Used Tommy Tape silicon rubber wrap (red stuff) to increase the diameter of the return pipe for the hose clamps.Its temp range is -60c to +200c.It bonds to itself and cures in 24 hours. $13 bucks from Bunnings.Earls clamps from the above post. Edited 11/01/11 06:56 AM by Skidude Link to comment Share on other sites More sharing options...
John Harvey Member 28 Member For: 15y 2m 2d Gender: Male Location: two wells....the bush Posted 28/02/12 01:27 AM Share Posted 28/02/12 01:27 AM So my earls oil line has started leaking in 2 places now and its gotta come back off.What have people found the best way too seal this bastard. Mine was perfect for a good 20000kms. I used sanded copper washers on the block and pressure switch, But never had to do anything with the filter itself but now that's leaking. Will thread tape do here?? Link to comment Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 4m 14d Gender: Male Posted 28/02/12 01:36 AM Share Posted 28/02/12 01:36 AM There was a discussion on that a while ago I think,, maybe ratter explaned that theres a push in tipe and screw in type.. 1 of the 2 kept leaking Link to comment Share on other sites More sharing options...
