360 rwkw. Ba Mk2.
Anchor
  • Replies 27
  • Member For: 18y 9m 8d
I have the coin sitting here... I'm going to get a cheap 4' mild steel one. I just need the time to order it... I am thinking of buying my own tuning software (Sct Race pro).. I have another person that is inerested also. So I may end up going shares in the Advantage III software instead....
  • Member For: 14y 11m 24d
And here is a video, re-doing the tune atm as they aren't happy with it.
One of the lower power runs while working up the boost. Dunno what it made here. 430hp I think?
Its never had a complete tune lol. Always been bits and pieces here and there. Went up about .7psi. Pretty good result. Top end is richer now too. Nice and fat :D
  • 2 months later...
New figure today. Gave it a small tickle on thursday for a dyno comp today. Dyno was either accurate or low because turboute79 made less power on it than the one mine was tuned on. Same day as well.
482rwhp / 360rwkw. Although the peak looks more like 495hp... The measuring line down the graph is after it peaks.. I'll try scan it.
14.7psi, 11.4 AFR. Pretty hot inside the shed.
So what does everyone make of this dyno sheet??
Edited by Anchor
  • 4 months later...
Bit of an update, I sold the ute to a local bloke here in rocky. He then took it to the drags with the mickey t's I had. Fastest run of 4 was 12.3 @ 113. Keep in mind its a 6sp manual, sitting on the bumpstops (full load down to powercruise and back f*cked everything). All on 359rwkw.
On the return road the timing chain jumped 6 teeth and bent all the inlet valves. Also done some damage to the valvesprings somehow. Cause was deemed to be some little plastic/rubber thingy went missing inbetween the cam gears that helps tension the chain as the main tensioner is in perfect condition.
So its getting a headjob and being bolted back together to see how far he can stretch the BA mk2 bottom end. Wants an 11 real bad :D
Dents in the pistons are minor, think of it as a free de-compress lol.
