What Actuator Is This?
Watto89
  • Member For: 16y 6m 23d
Gday, I recently got a new actuator put on and im wondering what type of actuator it is.
It has a bar code on it with
445963 - 135
58330 04160
The reason im asking is because ive had boost issues and im trying to figure out why my boost is rising to 16psi ~ before I back of the throttle.
And ive got the actuator connected directly to the turbo :)
  • Member For: 18y 9m 22d
It's a 6 lb actuator
depending on when the boost in inscreasing in the rpm, you could have a jammed flapper, bad actuator or in need of a port job and larger flapper.
Its a brand new actuator, and I can move the wastegate back all the way, there is no exhaust leaks or boost line leaks... shouldnt it only get to 6psi then stop?
it has a 4" dump to 5" Cat to twin 2'5", I can hold put my throttle to half and it will stay around 6, but when I go full it will rise to 16+ psi
