Are Fg Conrods Bigger Than Bfii Rods?
HI PSI
  • Member For: 18y 9m 9d
Hi all.... I have been offered a set of FG Conrods on thecheap and I am now considering throwing these into my spare BAII engine. I would dearly love a forged engine, but other commitments have priority. Money is tight.... So I am thinking of freshening the crank and bearings, Koneski Pump gears and retaining the standard pistons.. I am not chasing Monstrous power. I want a reliable 370 rwkw.. What are your thoughts?
  • Built F6 & VE SS-V
  • Member For: 17y 7m 10d
The rods are exactly the same from BF2 to FG as is the part number. Might be worth throwing a set of forged rods in if your budget allows, otherwise there are alot of people running those numbers safely with BF2-FG rods...
Nah I am fairly sure they are they same size as any BF Turbo rods built after 06/06, as I got an FG F6 block and the part numbers on the rods were exactly the same as the part number on my BF F6 rods. But what you will also find is it is actually cheaper to purchase FG parts are they are in current production, hope this helps.
Thank you very much. This is good to know. Someone told me that the FG F6's had argo rods... I check the prices on new ones today..The FG rods were $65 each retail....
  • Member For: 16y 8m 20d
I put a LOT of research into this when getting my FG F6 short motor (dozens of phone calls and over 30 e-mails). Even went as far as calling ARGO, who were rumoured to hav been the supplier of the rods.
The conrods DONT run the same part number (not for the 09 which my was), apparently it is due to the newer date and newer batch, and a different bush being used, but this is the only difference, same size and weight as BF2. The pistons on the other hand are as I have been told by multiple FPV dealers and suppliers, a forged unit.
  • Member For: 15y 4m 8d
wow $65 each, that's cheap as.
  • 1 month later...
  • Member For: 15y 20d
So what about the BF series 1. My ute's build date is 11/05,so are the Rods in my donk the same as whats in the BA ?? :beerchug: or are they the upgraded version ?
