  • Member For: 15y 5m 15d
Yeh it can be, will set you back between 1 & 2K from what I've seen.
few companies around that do aftermarket touch screens and the like
top end audio for example.
Chheers,
Matt
Guest XR09
  • Guests
ASL does sell them from $1700 - $1900 app. Then you need the looms, speakers, splits fron and rear. And have your ECU reflashed for it. It's not an easy job. And that does not include split air.
A lot easier to have it in the first place. A lot of cash and bother to upgrade to a colour screen.
  • Member For: 15y 1m 30d
I Have done it, but probably wouldn't do it again. I bought the car second hand and bought a premium ICC off of ebay, which was supposed to come with the sat nav and was one of the main reasons that I bought it, I also wanted the reversing camera.
I should have done a bit more research than I did as after buying the camera I found that I needed to replace the entire loom to be able to run the genuine Ford unit, (just buy an aftermarket kit from ACL instead, comes with everything needed).
I was planing on upgrading the speakers and adding my own amp anyway so wasn't worried about not getting that.
In the long run I wouldn't bother doing it again, I would just buy a car that comes with it all already.
Edited by frl0173
  • Member For: 17y 10m 19d
