  • Replies 37
  • Member For: 19y 9m 28d
There's only one guy in Melbourne with the old Dongle I know of and that's Nick aka "The Wog" XTC Performance. Is this him?
  • Member For: 17y 8m 18d
Run. Turn around and run and don't look back lest you turn into a pillar of turd.
  • loitering with intent
  • Member For: 21y 8m 17d
spit.gif Fark you Steph , I now have to change me Tenna Lady
  • Member For: 15y 8m 14d
I have this tapping noise also in roughly the same place you have mentioned. But it only seems to turn up after the car is warmed up after a 15min drive or so.
Is your car similar or does do it do it when its cold aswell?
Which test is more accurate a leak down test or a compression test?dontknow.gif
Edited by Brendan XR6-T
  • Member For: 16y 11m 29d
Compression test is for well... Compression, it will only check to make sure your pistons seal properly and that the piston reaches all the way up. So if you got a bent rod, the piston wont move up as far and hence, giving less compression. Also if you have a very old and worn engine, the rings might be cracked or the bore worn. Can all cause different readings. I think the normal for a B series was 195psi. that's off the top of my head, dont quote me.
I dunno if a leak test is a compression test or if different. Maby it only checks if the piston seals right and not compression.
I know a compression test is 100% accurate for its reading. I havent known any one to get less that optium readings in a car less that 250 thousand kays, and being a big straight 6, they dont rev hard and apprenty these engines dont wear much any way. You will get a read out like
Pot 1 : 190
Pot 3 : 190
Pot 2 : 98
Pot 5 : 102
Pot 4 : 190
Pot 6 : 132
I dunno the exact order of the pistons, I know there not 1 to 6 in order. A read out like that would surgest 3 f*cked pots, 2, 5, and 6.
Teena lady, is there anything they can't do?
