nzturbo Member 26 Member For: 15y 4m 6d Gender: Male Location: NZ Posted 17/07/10 05:40 AM Share Posted 17/07/10 05:40 AM Hi, My Door ajar light stays on, but all doors are shut.Is on a 03 XR6T.Problem with this is it will not let me lock the doors.Have given locks a gud shot of CRC with no change.Whats the best plan of attack ?????cheers Link to comment Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 13d Posted 17/07/10 05:50 AM Share Posted 17/07/10 05:50 AM Go to Ford and they can plug in the ids and tell you which one is at fault. Have you gone around and open and shut doors,boot and bonnet? If not,do that and see what happens. Link to comment Share on other sites More sharing options...
Gloo Member 403 Member For: 16y 9m 7d Gender: Male Location: Northern South Australia Posted 17/07/10 06:25 AM Share Posted 17/07/10 06:25 AM My old BA had a bodgy boot, fixed under warrenty... It closed fully, but if you pushed on it, the door light would crack the wobblies. Going over bumps it would lose its sh*t and start beeping at me. f*cked me right off. Nothing worse than doing a skid and all you can hear is beep beep beep beep. Link to comment Share on other sites More sharing options...
nzturbo Member 26 Member For: 15y 4m 6d Gender: Male Location: NZ Posted 18/07/10 05:13 AM Author Share Posted 18/07/10 05:13 AM Is on a ute fellas ......my bad.Gave it a gutsful of crc last night and it seems to be working today ??Is the switch in the latch itself ???cheers Link to comment Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 13d Posted 18/07/10 10:24 AM Share Posted 18/07/10 10:24 AM Yep,switch is part of the actuator/latch assy. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 19d Gender: Male Location: Probably above atmospheric pressure Posted 18/07/10 11:43 AM Share Posted 18/07/10 11:43 AM I've had the light stay on before, under warranty Ford cleared error codes and it stopped. No idea what caused it, but that was almost 2 years ago and it's fine since (BFII). Link to comment Share on other sites More sharing options...
nzturbo Member 26 Member For: 15y 4m 6d Gender: Male Location: NZ Posted 10/08/10 06:59 AM Author Share Posted 10/08/10 06:59 AM (edited) cheers mate , just checked actuaters , they appear to be fine.plugged in a new one and made no difference.Will have to take to fraud.By the way -SteveR- when your door warning light was on could you lock the car ??we cant , tried to lock and the horn sounds a couple times.?????Key dont work either ??????thx. Edited 10/08/10 07:12 AM by nzturbo Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 19d Gender: Male Location: Probably above atmospheric pressure Posted 10/08/10 09:07 AM Share Posted 10/08/10 09:07 AM Mine worked fine 100%. Software glitch I'd assume on mine! Link to comment Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 3m 4d Gender: Male Location: left right out Posted 10/08/10 10:31 AM Share Posted 10/08/10 10:31 AM If the horn sounds a couple times when you try to lock, then the comp thinks the door is open. Could be a dirty contact in the door lock/switch, or even a loose plug. Link to comment Share on other sites More sharing options...
nzturbo Member 26 Member For: 15y 4m 6d Gender: Male Location: NZ Posted 11/08/10 07:14 AM Author Share Posted 11/08/10 07:14 AM (edited) Cheers hawlass , will clean contacts and check plug.Rang ford today and they said they could not plug in to it and tell me the fault,They reckon possible water in plug at b pillar ??Utes got no plugs in b pillar !!!!!!Talked to a sparky too today and he new of a "Bim Module" ? packing a sad one .sound expensive what ever it is ......??????Just checked my warranty and it exp yesterday .......... Problem started weeks ago though so will ring them and see if they will cover me . Edited 11/08/10 07:16 AM by nzturbo Link to comment Share on other sites More sharing options...
