oldskool Member 144 Member For: 19y 2m 1d Posted 14/07/10 09:29 AM Share Posted 14/07/10 09:29 AM (edited) among other work I am getting done before the latest warranty runs out on the wifes n/a, wondering if people think this should be covered before I walk in and get the dealer run around. Getting other stuff check but this sh*ts me every time I get in the car. On the door arm the plastic insert has bubbled as ca be seen in the pics. Would these pieces be covered under warranty or is it a useless excuse like wear and tear?http://users.tpg.com.au/barwon3//IMG_8190.JPGI also have another interesting one, non permium sound when you have the radio on FM and turn the demister is turned on the radio losses signal. I knw this will be covered but wondering if other people have seen this. I know the aerial it on the back windscreen so can see how the two are related.thanks Edited 14/07/10 09:31 AM by oldskool Link to comment https://www.fordxr6turbo.com/forum/topic/69371-time-to-run-the-gauntlet-again/ Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 7m 10d Gender: Male Location: Southern Highlands NSW Posted 14/07/10 09:54 AM Share Posted 14/07/10 09:54 AM should have no probs with the silver bits Link to comment https://www.fordxr6turbo.com/forum/topic/69371-time-to-run-the-gauntlet-again/#findComment-1024481 Share on other sites More sharing options...
Xr50 Donating Members 196 Member For: 14y 9m 26d Gender: Male Location: Brisbane Posted 14/07/10 10:02 AM Share Posted 14/07/10 10:02 AM My young bloke has a BF XR with exactly the same problems, will be interested to find out the radio fault Link to comment https://www.fordxr6turbo.com/forum/topic/69371-time-to-run-the-gauntlet-again/#findComment-1024484 Share on other sites More sharing options...
oldskool Member 144 Member For: 19y 2m 1d Posted 14/07/10 10:07 AM Author Share Posted 14/07/10 10:07 AM (edited) really that's the least of my problems, im suprised the amount of issue switht he car considering its less than 3 years old and only has done 60,000k'so Rubber Mould new L/H mirror not fitted correctlyo Power steering pump leaking best viewed from underneath caro Oil leak front engine area best viewed from under car , head gaskets on both sides of engine show signs of oil leakage o Movement in front suspension L/H lower ball joint movemento Exhaust resonator split at rearo Radio when on FM turn on rear demister radio crackles, looses signal is unusablewill be an interesting chat with them, im worried about the oil leak, its currently a small one but it will only get bigger. no real signs of a blown head gasket. Edited 14/07/10 10:08 AM by oldskool Link to comment https://www.fordxr6turbo.com/forum/topic/69371-time-to-run-the-gauntlet-again/#findComment-1024485 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 3m 30d Gender: Male Posted 14/07/10 10:56 AM Share Posted 14/07/10 10:56 AM I had a silver door spear replaced under warranty Link to comment https://www.fordxr6turbo.com/forum/topic/69371-time-to-run-the-gauntlet-again/#findComment-1024511 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 4m 22d Gender: Male Location: Probably above atmospheric pressure Posted 14/07/10 03:21 PM Share Posted 14/07/10 03:21 PM +1 or silver insert under warranty. Had a couple small bubble lines. Also replaced a cracked side seat plastic. NO idea how it broke, I was sitting down normally and I'm not a big bloke at all, far from it, and CRACK! Fixed anyway... Link to comment https://www.fordxr6turbo.com/forum/topic/69371-time-to-run-the-gauntlet-again/#findComment-1024574 Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 10m 27d Posted 14/07/10 11:51 PM Share Posted 14/07/10 11:51 PM oldskool...is the power steering leak related to the leak from the front of the motor?...Or are there two distinct leaks as in one is power steering fluid and another motor oil...as I beleive I have a power steering leak also though I cant seem to pinpoint if its comming from the pump or power steering line... Link to comment https://www.fordxr6turbo.com/forum/topic/69371-time-to-run-the-gauntlet-again/#findComment-1024622 Share on other sites More sharing options...
oldskool Member 144 Member For: 19y 2m 1d Posted 15/07/10 05:57 AM Author Share Posted 15/07/10 05:57 AM not sure if it two seperate leaks or just both fromt he same area, will keep you posted. Must be a common issue sthough, I had my power steering pump replaced on my bf xr6t due to it leaking. Link to comment https://www.fordxr6turbo.com/forum/topic/69371-time-to-run-the-gauntlet-again/#findComment-1024692 Share on other sites More sharing options...
blackxr6turbo Member 61 Member For: 16y 2m 21d Posted 17/07/10 05:57 AM Share Posted 17/07/10 05:57 AM I asked for all my silver bits to be placed under warrenty, also got a new shifter and leather boot Link to comment https://www.fordxr6turbo.com/forum/topic/69371-time-to-run-the-gauntlet-again/#findComment-1025206 Share on other sites More sharing options...
