  • Replies 77
  • Member For: 15y 1m 26d
MAte if I was you I would get your stockers high flowed. Went from siemens 60lbs back to the stockers high flowed and car runs alot smoother and better fuel consumption. Actually I'm still running the same l/100 at 330rw to now.
Sydney based??
  • Member For: 18y 10m 24d
yes there have been alot of uscar EV14s fitted to FGs, I've been recomending Seimens, only for the plug n play factor, I have them in my FG and there's nothing wrong with them, they idle smooth and suppoort 400 easy, but the EV14s have been tuning up very smooth but with wiring issues a pain.
Now we have the new Xspurt EV14, which is a direct plug in and fit in the rail, a great refined injector.
So, if your on a tight budget, the Seimens will service you well, but if your happy to spend a bit more in the search for near perfect fuel delivery, these new Xspurt EV14s are the pick.
Edited by RAP1D
  • Member For: 16y 2m 24d
Is this the EV14 Chris?
They look very similar to the injectors I run.
Ive seen the Xspurts retailing at $250 (Xspurts). Will they be better priced then this?
  • Member For: 19y 9m 5d
The EV-14 with an EV-1 connector is a compressed natural gas (CNG)injector introduced a few years ago by Bosch. It's labelled the NGI2 for "natural gas" and explains why they have such a big flow rate. They were designed for a bi-fuel application to be easily integrated into OEM intake manifold designs. Never used them myself but just remember there are MANY different EV-14 injectors available with different flow rates, spray patterns, and 'matching'. The EV-14 with the twin spray and slight bent angle is the best for the XR6 port design, however it doesn't have enough flow which is why we have to use the EV-14's with the conical spray pattern in the high HP cars.
Knew I'd seen these injectors before, they are the injectors I am running in my FG. Brand name has changed to Xspurts since they were first released 4 months ago.
http://www.fordxr6turbo.com/forum/index.php?showtopic=58581&st=54
Great injector, been very happy with them.
These retail through Hiro for $140each in the 1000cc.
Edited by HIRO F6
  • Member For: 15y 6m 27d
Yep, I have these injectors as well. Been very happy with them, car idles better than the standard ones..
Once my new motor gets built, I'll see if my tunner can give me some data on them.
I bought mine through HIRO, would highly recommend them.
Ben
Hi Mate,
From my knowledge, all of the Xspurt range are provided with the connector to fit USCAR.
Bench tested at 3 BAR they are just under 900cc.
Edited by HIRO F6
