Standard Hub To Guard Measurement For Fg Xr6?
Jizza
  • Member For: 18y 4m 13d
For an XR6/T/F6 only:
Sedan (nominal figures at kerb weight)
Front: 366-369mm
Rear: 371-376mm
XR6 Ute, excluding c-cab and e-gas (again, nominal at kerb weight)
Front: 394-397mm
Rear: 395-400mm
Edited by bunna
  • Member For: 14y 9m 21d
Front: 366-369mm
Rear: 371-376mm
Front: 394-397mm
Rear: 395-400mm
Thanx Bunna, very informative:
Have just swapped the G6 Limited's springs and shocks front and rear for XR6 units, difference as follows.
Front was 385mm - now 373mm
Rear was 390mm - now 375mm
Will be interesting to see how / if it settles further.......handling is obviously much improved. Since new (now 15,000km) The G6 stock was crap as expected in corners but over bumps and surface changes it was horendous, worse than the old BF XR6 with 80,000km on it. Surprisingly that is now fixed also.....
Wonder if Pedders can examine the stock units I took out and tell me if they were stuffed so I can take them to the dealer with some lube........ 5 times back there in 6 months and they couldnt find an issue, till the front sway bar had rattled its way loose.
Interesting they were also the last to have the wheels off, front right wheel nuts today were little more than hand tight
Edited by Jizza
hmmm - those numbers are a little high for G6 suspension...
front 374-377mm
rear 383-388mm
Keep in mind I have tables for alignment angles for every model from heights of 340-410mm at the front and 300-400mm at the rear, so its not like being a little bit off nominal is a bad thing.
