yeggles Member 5 Member For: 14y 8m 4d Posted 30/06/10 09:10 AM Share Posted 30/06/10 09:10 AM gday lads, not much of a poster but keen to get more involved anyway, as the title describes, read a few different posts and word of mouth that seem to conflict regarding an exhaust upgrade.I recenlty purchased an XR6T and lookin at gettin around 260-270kw at the wheels, planning on flash tune, injectors, acuator, CAI (I should be able to get it done this weekend) and maybe an catback exhaust and should acheieve what I want. I dont want the exhaust for the note but rather performance gain (and a sexy twin tip ;D) so just curious to find if its worth doing and if its good bang for you buck upgrade what brand of cat should I be lookin for? etc.thanks fellas Link to comment Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 6m 15d Gender: Male Location: Victoria Posted 30/06/10 09:55 AM Share Posted 30/06/10 09:55 AM More info... If it's a bf... You'll just need injectors and a tune to get that figure...The exhaust flows well for stock... Replace with a high flow cat and pull out a center muffler and it's good for 350rwkw...Actuator won't be needed for 11 psi which is what you'll need for that figure...Change your air filter to a k&n... Get a typhoon intake on your airbox...Get some wrx iridium spark plugs... And a tune...If you did what you have said and put a fuel pump plus intercooler, you'll see 320rwkw... Link to comment Share on other sites More sharing options...
yeggles Member 5 Member For: 14y 8m 4d Posted 30/06/10 10:24 AM Author Share Posted 30/06/10 10:24 AM oops I should of mentioned its a BA.yeah im adding a typhoon intake with k&n filter this weekend if I get time.also another Q, if I get the exhaust modded in any way, will I need a tune straight away or can I wait a month or two until I get a flash tune/injector compbo? cheers Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 19d Gender: Male Posted 30/06/10 10:52 AM Share Posted 30/06/10 10:52 AM u can drive around no probs but just dont flog it. I would do the actuator also or slse u will have sh*t bottom end power. as for the exhaust, just gut the cat. Link to comment Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 6m 15d Gender: Male Location: Victoria Posted 30/06/10 01:57 PM Share Posted 30/06/10 01:57 PM As soon as you do cat you will need to drive off boost until you get a tune...It will cause heaps of overboost...Do cat, drive to tuner, get actuator fitted... And tune it Link to comment Share on other sites More sharing options...
FAST-XR EVIL T Member 259 Member For: 16y 1m 28d Gender: Male Location: Liverpool NSW Posted 01/07/10 05:50 AM Share Posted 01/07/10 05:50 AM as the others have said, the only exhaust mod you need to do is the cat...get a cat off rapid systems, 5" 100 cell, about $170even at 270rwkw youll be pushing around 10psi, so id recomend getting a half decent cooler, itll be ok in winter, but wait till summer comes! Link to comment Share on other sites More sharing options...
yeggles Member 5 Member For: 14y 8m 4d Posted 01/07/10 08:08 AM Author Share Posted 01/07/10 08:08 AM thanks guys Link to comment Share on other sites More sharing options...
yeggles Member 5 Member For: 14y 8m 4d Posted 02/07/10 07:06 AM Author Share Posted 02/07/10 07:06 AM another q, ive done a bit more research and noticed some people replace the center muffler with a hotdog instead of just a straight through piping, im guessing for exhaust note? any other reason? cheers Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 3m 12d Gender: Male Location: Far north queensland Posted 02/07/10 07:24 AM Share Posted 02/07/10 07:24 AM on early ba's it gives more flow, everything after that is just more note. I have one allready done but due to the size it'd be cheaper just to gets yours done. Link to comment Share on other sites More sharing options...
FOONIN Donating Members 678 Member For: 15y 9m 8d Gender: Male Location: CHCH NZ Posted 04/08/10 04:03 AM Share Posted 04/08/10 04:03 AM if exhaust replaced from cat back would car need tune? or is it only if you replace dumpy/cat then it requires a tune?? Link to comment Share on other sites More sharing options...
