Choppachang Member 4 Member For: 13y 11m 8d Gender: Male Posted 06/08/11 11:26 AM Share Posted 06/08/11 11:26 AM I got an 09 (standy) which has a mild whine and clunk at 37 thou , took it to Sunshine Ford in Southport and went for a burn with the workshop manager and he had no probs ordering me a replacement diff, that was Monday so should see it sometime in the next few weeks ... Link to comment https://www.fordxr6turbo.com/forum/topic/69073-fg-diff-noise/page/4/#findComment-1130675 Share on other sites More sharing options...
gixxer New Member 12 Member For: 13y 11m 21d Gender: Male Location: townsville Posted 07/09/11 07:41 AM Share Posted 07/09/11 07:41 AM my fg had new diff after 3000ks thinking if it goes again will replace with 9inch diff Link to comment https://www.fordxr6turbo.com/forum/topic/69073-fg-diff-noise/page/4/#findComment-1138585 Share on other sites More sharing options...
DEDLYWEPN Member 11 Member For: 15y 6m 9d Gender: Male Location: WA Posted 29/09/11 06:21 AM Share Posted 29/09/11 06:21 AM I've had two diffs fail (one basically exploded and spewed diff oil all over my new garage floor) and a tailshaft shear in half, all within 65,000kms. Plus diff bushes failing on average every 15-20,000kms. Under-engineered for the torque I think, when will Ford get with the program and realise the need to make some drastic changes to their drivelines. The ZF seems to be the only reliable driveline component *touch wood*Josh Link to comment https://www.fordxr6turbo.com/forum/topic/69073-fg-diff-noise/page/4/#findComment-1144925 Share on other sites More sharing options...
wilba Member 828 Member For: 16y 5m 28d Gender: Male Posted 24/10/11 10:24 PM Share Posted 24/10/11 10:24 PM X2 On 14/07/2011 at 11:01 AM, omie_747 said: im having the same issue in my FG turbo ute!!Diff has gotten really clunky and rattley.... when launching hard and coming to a stop, on idle it makes a bad vibration/clunking sort of noise from the back (more the left hand side), then I cruise and its all gone....Its really got me stuffed! on the hoist both wheels dont spin at the same time when one tyre is rotated.cars engine is modified, suspension is herrords kit, any suggestions or advice?thanks allot Link to comment https://www.fordxr6turbo.com/forum/topic/69073-fg-diff-noise/page/4/#findComment-1153367 Share on other sites More sharing options...
wilba Member 828 Member For: 16y 5m 28d Gender: Male Posted 31/10/11 03:09 PM Share Posted 31/10/11 03:09 PM So does anybody now what the problem is ? Link to comment https://www.fordxr6turbo.com/forum/topic/69073-fg-diff-noise/page/4/#findComment-1155443 Share on other sites More sharing options...
unclewal Donating Members 583 Member For: 14y 7m 10d Posted 31/10/11 09:41 PM Share Posted 31/10/11 09:41 PM Ford and not spending the money to get it right the first time? My diff has been knocked back under warranty since new, since I have now modified the engine the diff is definately not going to get fixed. From what I have been told the drive shaft and the actual lash in the diff gears arent set to small enough tollerances and over time (albeit little time) the lash in the driveline leads to knocking and clunking when the driver backs off or gets on the gas. A small tollerance not set properly in several components over lots of different components adding another small gap means a big gap over the length of the driveline and results in a clunk when all the parts move in sequence. I know we shouldnt have to as a customer that's paid good money but I am going to get after market gear and be done with fraud sh*t once and for all early next year one time bank pain for long term satisfaction. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/69073-fg-diff-noise/page/4/#findComment-1155460 Share on other sites More sharing options...
wilba Member 828 Member For: 16y 5m 28d Gender: Male Posted 01/11/11 06:24 AM Share Posted 01/11/11 06:24 AM Yea mine does really do it when I'm on and off the peddle it does it in like car parks and slow slow drive like 20k/ph Link to comment https://www.fordxr6turbo.com/forum/topic/69073-fg-diff-noise/page/4/#findComment-1155556 Share on other sites More sharing options...
Guest XR09 Guests Posted 01/11/11 08:32 AM Share Posted 01/11/11 08:32 AM I blew the std one. Put in a Kaaz. Was told they were great. Talk about noisy and bring out the driveline shunt.. Now a tremac. Not bad. Nice after the Kaaz.The diffs are not that noisy. The way the rear end is mounted makes for a noisy rear end.And the more you go away from the stock height. As in lower it. The noisier it will get.I'm sure some sound proofing would go a long way. Pull up your wafer thin carpet and looks what's under it...... Link to comment https://www.fordxr6turbo.com/forum/topic/69073-fg-diff-noise/page/4/#findComment-1155610 Share on other sites More sharing options...
wilba Member 828 Member For: 16y 5m 28d Gender: Male Posted 02/11/11 02:20 PM Share Posted 02/11/11 02:20 PM With mine the diff isn't noises it clunks like a locked diff or sumthin like that but only from the left wheel at slow speed Link to comment https://www.fordxr6turbo.com/forum/topic/69073-fg-diff-noise/page/4/#findComment-1156016 Share on other sites More sharing options...
wilba Member 828 Member For: 16y 5m 28d Gender: Male Posted 10/11/11 09:25 PM Share Posted 10/11/11 09:25 PM Well changed the diff oil the other day and wat do ya no the clunking from the rear went away ^_* Link to comment https://www.fordxr6turbo.com/forum/topic/69073-fg-diff-noise/page/4/#findComment-1158528 Share on other sites More sharing options...
