Fords Rule Member 38 Member For: 15y 10m 19d Gender: Male Location: Penrith Posted 27/06/10 01:25 AM Share Posted 27/06/10 01:25 AM I have a couple of questions to ask if I may.When I bought my BF 06 mk2 turbo in Jan this year the fella a bought it off told me he had a capa flash mild tune (the model that is now being made redundant)and a brand new set of (siemen) (spelling?) decca 60 injectors ready to install and said he would do it for nothing as he had no need for them now.So I agreed and my question now is if I wanted to go back to stock and flash back to factory do I have to change back to the factory injector size or are the decca 60's still ok to use.And if they are would I just leave them in or go back to the standard ones.Will the standard ones save on fuel or doesn't it matter?Also I made a my mechanic put in titanium tip plugs and they were gapped at 130 and I gave it a boot full doing around 140 ish on boost @ 10 psi with a full tank of juice and it spluttered and farted..Was this because the gaping was all wrong.I rang him up and asked him what gap he had set as I was thinking about it as it was only 2 days after he changed them for me.And I have been told since that copper is a better conductor than titanium so should I dish the Titanium plugs and go the copper with an 0.90 gap or similar.Your help and aswers to my questions would be greatly appreciated.Cheers Mark. Link to comment https://www.fordxr6turbo.com/forum/topic/69041-going-back-to-stock/ Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 19d Gender: Male Location: @ my laptop Posted 27/06/10 01:41 AM Share Posted 27/06/10 01:41 AM You will be lucky if the car starts let alaone run at all with the 60 lb injectotrs and the standard tune, if it does, it will run excessivley rich which can do damage to certain items and wash down your bores.Your car should be running in closed loop fuel control when driving normally so fuel economy really should be the same in theory, but there are a lot of things that will influence it.You need a plug with a smaller gap than standard when running higher boost.Plugs are normally iridium type and should not have the gap adjusted, the correct gapped plug should be purchased. Link to comment https://www.fordxr6turbo.com/forum/topic/69041-going-back-to-stock/#findComment-1019441 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 7m 20d Gender: Male Location: Far north queensland Posted 27/06/10 02:35 AM Share Posted 27/06/10 02:35 AM wrx plugs come pregapped for you Link to comment https://www.fordxr6turbo.com/forum/topic/69041-going-back-to-stock/#findComment-1019446 Share on other sites More sharing options...
Fords Rule Member 38 Member For: 15y 10m 19d Gender: Male Location: Penrith Posted 27/06/10 08:27 AM Author Share Posted 27/06/10 08:27 AM Thankyou Ratter and Sideways82 for taking time to answer my questions. You have made things alot clearer for me.This is why this site is so valuable to dummy's like me. Cheers Mark Link to comment https://www.fordxr6turbo.com/forum/topic/69041-going-back-to-stock/#findComment-1019531 Share on other sites More sharing options...
Smoke them tyres Member 557 Member For: 17y 5m 24d Gender: Male Location: Brisbane Posted 27/06/10 11:02 AM Share Posted 27/06/10 11:02 AM (edited) Mark,Not a dummy.....at least you know to ask the question... Edited 27/06/10 11:04 AM by Smoke them tyres Link to comment https://www.fordxr6turbo.com/forum/topic/69041-going-back-to-stock/#findComment-1019585 Share on other sites More sharing options...
Fords Rule Member 38 Member For: 15y 10m 19d Gender: Male Location: Penrith Posted 28/06/10 10:06 AM Author Share Posted 28/06/10 10:06 AM Smoke Them Tyres. Link to comment https://www.fordxr6turbo.com/forum/topic/69041-going-back-to-stock/#findComment-1019801 Share on other sites More sharing options...
