  • Member For: 15y 3m 11d
So, my ute is too low to fit the generic X-Force 4" dump with 3.5" system. Won't go over the diff properly. So I've come to a solution. And I like being different/difficult.
After buying the following parts from Chris @ Rapidsystems (should be here monday) we'll be making a custom system up.
X-Force 4" dump
X-Force Hiflow cat
1x ???? 3.5" hiflow muffler
2x 180deg Mandrel 3.5" bends
2x 45deg Mandrel 3.5" bends
After going through the modification guide a few times, taking a visit into QT and talking to a mechanic who does mod plates I've decided to go towards the diff as usual, then go up over the rhs chassis rail and dump between rail and sideskirt. Basically in behind the XR6 badge. Of course not at a degree more than 45 and less than 15 as per rules. Being a ute, it will be far enough back, and out to the RHS and not past the outside of the car.
Only going for around 350rwkw. Standard BA bottom end is the holdup. Have all the other supporting mods either on the car or in freight.
Has anybody done anything like this before?
How do you guys think I'll go with the local police boys? Legal doesn't mean anything to them, if they don't like it, they'll defect it..
Any tips?
See page 4. Exhaust.
Queensland Transport Modifications Guide
I'll update this with pics as it gets done.
Cheers
Jeri
Edited by Anchor
https://www.fordxr6turbo.com/forum/topic/69009-exhaust-out-side-on-ute/
  • Replies 31
  • Member For: 16y 5m 1d
Theres a AU XR8 ute going around the Redlands in Brisbane that has done pipes out the side of the tray behind the cabin. Speaking to him he's had nothing but defects from QT and has to return in back to out the rear before going over the pits.
Looks and sounds awesome though. Love to see you do this to a 6t. :spoton:
Yeah, but its legal.... According to Queensland Transport and a number of exhaust shops. Most of them don't like doing it though for some reason.
I'll be down for powercruise so you can check it out then Hiro :D
As for defects, I'm on 1pt good behaviour for another 340ish days.. So much for staying under the radar...
Also, keep in mind this won't be visble out the side.. May even have a dummy xr6 non turbo tip out the back...
Ute goes in to get resprayed and de-badged on the 5th so this could all work out pretty well... Hmmm
Pity I just ordered the V3 kit all polished haha.
Edited by Anchor
  • Hitting the apex
  • Member For: 16y 8m 3d
My exhaust was hitting on my diff and catching on every hump in the road, after breaking the dump pipe off twice and pulling the turbo off my manifold the last time I cut a section out where the flange is under the driver and welded the pipes together.
Exhaust is now about 30mm shorter and now misses my diff, scrapes every now and then but a lot better now
Reving at 5-6k sounds a bit funny now though
  • Member For: 21y 9m 17d
Dave (blueboost) has done or tuned a car locally to him in Mackay with a side setup from the standard system. Basically its a pipe exiting from near the cat that has a wastegate on it and only opens at a desired boost level dumping all the gas.
So basically its like a screamer pipe, sort of! Normal driving its totally standard until the loud pedal is mashed...
Ingenius and effective plus cheap so no need for a aftermarket exhaust or the noise.
Ooops, Didn't read your post fully! anyway the above I wrote is an excellent idea none the less.
Edited by bjc
Yeah I had thought of something like that. Or a Y pipe with one of them electric flap things. But I'm trying to keep it legal.. 1pt for a year here.
  • Member For: 17y 10m 4d
There is a Persuit ute here in subiaco that has the pipe out the side. Looks awesome. hvent heard it yet though, it always at the panel beaters getting something done I guess.
Its blue if anyone knows it.
  • Member For: 16y 2m 24d
This is a xr8 in Brisbane as far as I know, kinda what you're going for? From what I know its legal to have the side exit as long as you follow all the specifics to do it properly but if the cops dont know the rules they will still defect it if they think its illegal
