cranny Donating Members 123 Member For: 17y 2m 24d Gender: Male Location: Sydney NSW Posted 24/06/10 08:51 AM Share Posted 24/06/10 08:51 AM Hi Guys, I have a 2006 BF phoon I need to change pads and rotors and weighing up the price it is worthwhile upgrading the whole lot. now I know the FG 6 Pot Brembo Kit wont bolt straight up so what is required to bolt these on my BF. Cheers Guys Link to comment https://www.fordxr6turbo.com/forum/topic/68988-fg-brembos-to-bf/ Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 8m 25d Gender: Male Posted 24/06/10 09:08 AM Share Posted 24/06/10 09:08 AM think its the bracket that has to be modified/changed.. correct me if im wrong? Link to comment https://www.fordxr6turbo.com/forum/topic/68988-fg-brembos-to-bf/#findComment-1018851 Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 20y 6m 19d Gender: Male Location: SoR, WA Posted 24/06/10 09:40 AM Share Posted 24/06/10 09:40 AM Brackets are just to be flipped from one side to the other. Need to get new cross over lines made and swap the nipples with the cross over from end to end. Link to comment https://www.fordxr6turbo.com/forum/topic/68988-fg-brembos-to-bf/#findComment-1018867 Share on other sites More sharing options...
cranny Donating Members 123 Member For: 17y 2m 24d Gender: Male Location: Sydney NSW Posted 25/06/10 07:55 AM Author Share Posted 25/06/10 07:55 AM Thanks Guys, anyone done this first hand. I know they will fit but the brake guy said that they will work fine the only problem being is Pad wear will be worse because the three pistons are sml meduim and large and reversing that will cause excess pad wear has anyone succesfully fitted these to a bf if so what do they stop like and what is your pad wear like Cheers guys all input is helpfull Link to comment https://www.fordxr6turbo.com/forum/topic/68988-fg-brembos-to-bf/#findComment-1019080 Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 20y 6m 19d Gender: Male Location: SoR, WA Posted 25/06/10 08:36 AM Share Posted 25/06/10 08:36 AM On 25/06/2010 at 7:55 AM, cranny said: Thanks Guys, anyone done this first hand. I know they will fit but the brake guy said that they will work fine the only problem being is Pad wear will be worse because the three pistons are sml meduim and large and reversing that will cause excess pad wear has anyone succesfully fitted these to a bf if so what do they stop like and what is your pad wear like Cheers guys all input is helpfullI have mate. I have FG 6 pots on my BF and as your brake guy said that's why you need to swap everything around due to the piston set up.If you want pm me and I will give you my number to call me and talk about it.CheersAdrian Link to comment https://www.fordxr6turbo.com/forum/topic/68988-fg-brembos-to-bf/#findComment-1019091 Share on other sites More sharing options...
