Process West Member 248 Member For: 18y 6m 10d Gender: Male Location: Wollongong NSW Posted 23/06/10 10:35 AM Share Posted 23/06/10 10:35 AM (edited) Found this on another forum...best video Ive seen in a whileMark Mariani incar video on Vimeo Edited 23/06/10 10:37 AM by Process West Link to comment Share on other sites More sharing options...
GreenXR6T Donating Members 630 Member For: 19y 3m 9d Gender: Male Location: NSW Posted 23/06/10 02:19 PM Share Posted 23/06/10 02:19 PM One wild ride there Link to comment Share on other sites More sharing options...
4DZILR Donating Members 713 Member For: 14y 10m 7d Gender: Male Location: Sydney - Brighton Le Sands Posted 23/06/10 11:01 PM Share Posted 23/06/10 11:01 PM fark me dead... :turboboink: I salute him! Link to comment Share on other sites More sharing options...
bluprinturbo Donating Members 605 Member For: 16y 7m 1d Gender: Male Location: brisbane Posted 24/06/10 12:03 AM Share Posted 24/06/10 12:03 AM Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 18d Gender: Male Location: Probably above atmospheric pressure Posted 24/06/10 04:51 AM Share Posted 24/06/10 04:51 AM WHOOOOOAHHHHHHThe blur...hahaha!!!!Was hoping for an outside mounted view too though. Link to comment Share on other sites More sharing options...
EZ2CME Formerly XR6NA Member 3,512 Member For: 19y 12d Gender: Male Location: Brisbane Posted 24/06/10 07:45 AM Share Posted 24/06/10 07:45 AM That is insane! Link to comment Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 12d Gender: Male Location: Melbourne Posted 24/06/10 08:56 AM Share Posted 24/06/10 08:56 AM Oh my god! How the hell can he see what he's doing? lolThat's insane Link to comment Share on other sites More sharing options...
Ryan Donating Members 235 Member For: 16y 11m 3d Gender: Male Location: Sydney Posted 24/06/10 09:47 AM Share Posted 24/06/10 09:47 AM Holy Hell!!! get in, sit down, strap in and HOLD THE FARK ON for dear life!!!! Link to comment Share on other sites More sharing options...
RegSpec Cruise Control 1,417 Member For: 17y 11m 14d Gender: Male Location: Macksville NSW. Posted 24/06/10 01:18 PM Share Posted 24/06/10 01:18 PM (edited) A few specs on these things for those who haven't already seen them.....One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows at the Daytona 500.* Under full throttle, a Top Fuel dragster engine consumes 11.2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.* A stock Dodge 426 Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.* With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.*At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the flame front temperature measures 7050 degrees F ( 3900 degrees C ).* Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapour by the searing exhaust gases.* Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.* Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow.* If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to either blow cylinder heads off the block in pieces, push the crankshaft out of the bottom of the block and/or split the block in half.* In order to exceed 300 mph in 4.5 seconds dragsters must accelerate at an average of over 4G's. In order to reach 200 mph well before half-track, the launch acceleration approaches 8G's.The NASA space shuttle launches at about 5.5G's.The negative G force under dual parachutes at the end of the strip can generate up to 6G's.If you had no harness, this would throw you right out the front of the car.* Dragsters reach over 300 miles per hour before you have completed reading this sentence.* Top Fuel Engines turn approximately 540 RPM's from light to light! but stop & ponder the fact that the engine is only used for aprox. 4 to 5 seconds.* Including the burnout the engine must only survive 900 revolutions under load.* The red-line is actually quite high at 9500 rpm.* The Bottom Line; Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated $1,000.00 per second. The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter mile 10/05/03, (Tony Shumacher).The top speed record is 333.00 mph (533 km/h) as measured over the last 66' of the run (09/28/03 Doug Kalitta).*Putting all of this into perspective:You are riding a typical current MotoGP bike. Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start.You run the MotoGP bike hard up through the gears and blast across the starting line and past the dragster at an honest 200 mph (293 ft/sec). The tree' goes green for both of you at that moment. The dragster launches and starts after you. You keep your wrist cranked hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds the dragster catches and passes you.He beats you to the finish line, a quarter mile away from where you just passed him. Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1320 foot long race course.That, folks, is acceleration. Edited 24/06/10 01:26 PM by BionicXR6T Link to comment Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 3m 24d Gender: Male Location: Broady, Melbourne Posted 24/06/10 02:44 PM Share Posted 24/06/10 02:44 PM Just a bit ay. Link to comment Share on other sites More sharing options...
