rockafellqeinstien Member 325 Member For: 16y 7m 14d Posted 23/06/10 02:53 AM Share Posted 23/06/10 02:53 AM Jus a quick update for anyone with an FG. I replaced my 4 rotors with RDA slotted (for a bit over 400 bucks) and the improvment was huge! I used to get mucho brake shudder (ok I had 100k + on the oriuginal rotors).very cheap upgradeI found that the rears were the bigest culperit at speeds less than 100kmh (I replaced these first) but slowing from 100+ caused the fronts to get some very bad vibrations happening. All good now (new good quality pads on the front also) but I need to do the brake fluid after bedding in.Dont forget to cleen the hubs with some sand paper (my right front was pretty bad).And as for the obligitory stuff up when ever I work on my car - well dont use a "long" 15mm socket to undo the bolts for the calipers because as you undo the top one you will wedge the ratchet against the shock so tight that you wont be able to switch the selector on it to unwedge it (but you can just undow the bottom bolt and the caliper and disk will loosen - only took me 45 mins to figure that one out) Link to comment Share on other sites More sharing options...
riki83 Silver Donating Members 384 Member For: 15y 20d Gender: Male Location: Kellyville, Sydney Posted 23/06/10 05:26 AM Share Posted 23/06/10 05:26 AM another cheap upgrade, 6pot brembos and rotors $2100 Link to comment Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 7m 15d Gender: Male Location: Victoria Posted 23/06/10 07:02 AM Share Posted 23/06/10 07:02 AM Give them time champ!!! They might still warp or only last 10000km...DBA all the way I say!!! Link to comment Share on other sites More sharing options...
riki83 Silver Donating Members 384 Member For: 15y 20d Gender: Male Location: Kellyville, Sydney Posted 23/06/10 09:27 AM Share Posted 23/06/10 09:27 AM (edited) DBA 5000s 2 piece on there way Edited 28/06/10 06:42 AM by RHR No need to quote above post. USE FAST REPLY Link to comment Share on other sites More sharing options...
arjey VOTE ROOTSTER 2010 Member 591 Member For: 16y 5m 26d Gender: Male Location: Wollongong Posted 26/06/10 12:17 PM Share Posted 26/06/10 12:17 PM Give them time champ!!! They might still warp or only last 10000km...DBA all the way I say!!!HELL YES! Just put DBA 4000XS in my car today, even though its the first day.. I have fallen in love with the car again! My stop button is better! Link to comment Share on other sites More sharing options...
PSI40T Member 448 Member For: 18y 19d Posted 28/06/10 05:17 AM Share Posted 28/06/10 05:17 AM how much did they set you back? im thinking of doing the same thing to my fg xr6t.... pm me if u want... Link to comment Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 7m 21d Gender: Male Location: Perth, Western Australia Posted 02/01/11 03:28 AM Share Posted 02/01/11 03:28 AM And as for the obligitory stuff up when ever I work on my car - well dont use a "long" 15mm socket to undo the bolts for the calipers because as you undo the top one you will wedge the ratchet against the shock so tight that you wont be able to switch the selector on it to unwedge it (but you can just undow the bottom bolt and the caliper and disk will loosen - only took me 45 mins to figure that one out)I change pads on my BFII taxi regularly. I don't use a 15mm socket at all - just get a 15mm ratchet spanner and the job becomes a LOT easier.You'll pay about $40-45 for a good quality one at a tool shop. Bunnings have cheap ones as well. Link to comment Share on other sites More sharing options...
