  • flame magnet
  • Member For: 17y 1m
I have xenon lights in low and hi beams, and am thinking about putting another set in the fog lights. :o I live in the hills and do alot of driving through the forest etc.
I'd like to hook them up to my normal high beam switch. will the circuit take it or should I leave it on the fog light switch (not too convenient though).
cheers
scott
https://www.fordxr6turbo.com/forum/topic/68895-hid-kit-in-foggies/
  • Sucker
  • Moderating Team
  • Member For: 21y 1m 22d
I assume the foglights would be powered by a relay tapped off the parking light circuit...so if you could just swap that over to the high beam circuit you'd be laughing. Assume the relays are in the engine bay fusebox so shouldn't be too much trouble.
  • Member For: 16y 5m 19d
Get a H3 or an even smaller H3C kit and start from there. Might have to lengthen the cables if want to put the ballasts in the engine bay or find a safe spot in the front bar somewhere.
  • flame magnet
yeah true. what is an h3c kit? neveer heard of it :beerchug:
  • Member For: 16y 8m 7d
Hi. H3 and H3c kits will be the same, the biggest problem is holding the lamp into the reflector as the clip that goes over the back of the normal H3 globe wont fit over a HID globe, What you need to do is drill two small holes in the lip around the edge of the globe holder on the reflector and hold the new globe in with 2 self tappers. Cheers MD
  • Member For: 15y 4m 11d
is this for the xr6 foggies?
yeah it will fit. did it myself.. had them on the xr6 lights. The inside protective cover to reflect the light just needs to be pushed in a little..
then you will need a rubber washer to elevate the globe out of the fog light housing. then all I used was a paper clip to and welded it to the original bezels and twisted it around the head of the globe.
now I have them in my f6 lights as I have changed my bar. had to drill the globe cover but used the original grommet you get with the hid kits to seal the whole. turned out awesome! :)
its a lot of work but take your time and youll figure it out :)
  • 2 months later...
  • 2 weeks later...
  • flame magnet
ive got a kit coming- gonna be a bit of mucking around to get them to fit. h3c kit.
ebay ftw!:roflmbo:
