  • Member For: 15y 10m 26d
Hi, just noticed tonight that the Airbag /safety belt pretensioner light is coming on while driving. It doesnt seem to be on constant, more when hit the bumps and stuff but even just little bumps make it illuminate.
Any help on information is appreciated, and I cant quite remember but is the control module behind the ICC for the Airbag/Safety belt pretensioners.
  • 2 weeks later...
  • Member For: 17y 7m 24d
If its a ba/bf check the plugs under the front seats, located near the front- just slide the seats all the way back. in my old ba the passengers side plug would work loose and cause the airbag light to come on and off at random. Easy to knock them when vacuuming the carpets too. Just push them back together tight.
  • Member For: 16y 6m 27d
thanks for the reply.
Yeah it's a ba ute. The plugs under the seat are in tight but the one behind the stearing wheel was a little loose, pushed it tight but still have the same problem...
Is there anywhere else I might be able to check?
  • Member For: 16y 2m 3d
I talked to a local ford dealer about this issue as I get it...I notice it when my passenger seat position changes from foward to right back. The ford dealer said that "reoffending" sensors can be taken out and hard wired in
