Center Console
FOONIN
  • Member For: 15y 9m
charcoal, I originally bought a can of charcoal coloured spray paint to paint the fins under the rear of car from repco in a small can. The painters matched the colour to the can lid. But yeah just charcoal
  • Replies 34
Posted Images
  • Member For: 17y 2m 20d
at the same stage myself, try using a straightened coathanger- or bit of #8 wire, come in from the top,pointing wire rearwards, down a bit ,then forwards -this worked for me on the passengers side. Drivers side is easy, same coathanger from top, towards the traction /fog switch.
I was able to get half way down the passenger side. If you tkae glovebox out you can see up to the top just. Ill give it another go next weekend. Did you have to make the whole at the top bigger to fit all the cables??
I gently pulled the shifter surround up and off, removed the two rear screws holding the side trims on, took them off.This exposes the two screws each side at the bottom of the icc (4 screws total). take those out, and the two screws holding the tissue box in-remove this too. Now just remove the top screw where the pod goes and you can GENTLY ease the icc forward about 10mm. Pull the top of the icc forward and it will sit out on the top mounting lugs and give you the room you need. I bent the coathanger with a slight curve outwards,put it down halfway then worked it towards the front. If you feel around from underneath you will feel it and be able to pull it down.
im using these custom made: gauges but in a pod to suit BA/BF unlike FG pod shown in picture
with XR6 turbo as the background writing
Edited by osonvs
  • 1 month later...
