RAP1D Member Donating Members 3,739 Member For: 19y 28d Gender: Male Location: Sydney NSW Posted 28/07/11 12:37 AM Share Posted 28/07/11 12:37 AM Plazmaman surge tank has a larger volume tank and threaded fuel hose fittings.The larger volume allows you to run more power longer through the top gears... we have a few 500kw + customers that have run lean at the top of 4th gear with surge tank that is emptying itself befor it can be filled, a bit more volume only helps here.Screw in fittings on the tank are a great feature, if you go to a new billet/after market rail you can use dash screw in fitting directly on the pump, rather than the stock click on fittings.I have the Plazmaman fitting guide if anyone would like it.It's in PDF format and is 14 pages long, so think befor you print lolchris@rapidsystems.com.auEmail me if you need a copy. Link to comment https://www.fordxr6turbo.com/forum/topic/68843-plazmaman-front-mount-surge-tank-with-044-pump-fitting-instructions/page/2/#findComment-1127217 Share on other sites More sharing options...
