Ricky N Member 93 Member For: 16y 1m 13d Gender: Male Location: QLD Posted 05/07/10 01:57 PM Share Posted 05/07/10 01:57 PM if theres play back and forward then it needs new thrust washer, if theres not much up and down then you wont be able to see much rubbing because its not rubbing up and down but it will be rubbing on the inside of the compressor housing, if you pull the housing off you will see it....the oil on the inlet is just from the breather, if the oil is after the compressor then the seals are shot too....I had oil pissing out of both sides of the cartridge on my bike(dump pipe and boost piping)you might get away with pulling it apart and putting in a new thrust washer, im not sure about the inside workings of bb turbo though I have only pulled bush ones apart and changed bushesp.s. that's intake side of the compressor not the outlet as you called it.....Garrett BB turbos use angular contact ball bearings to take up thrust loads so they don't have thrust bearing/washer's like journal bearing T04 T03 turbos. Link to comment https://www.fordxr6turbo.com/forum/topic/68740-is-my-turbo-stuffed-vids-n-pics/page/2/#findComment-1021965 Share on other sites More sharing options...
Ricky N Member 93 Member For: 16y 1m 13d Gender: Male Location: QLD Posted 05/07/10 02:11 PM Share Posted 05/07/10 02:11 PM What was that banging noise when you were playing with it with your fingers?Was it in the back ground or was it happening when you pushed and pulled on the compressor wheel?By the sounds of it and the amount of play looks like it has collapsed bearings but I am not going to even try to give an exact diagnosis over the internet. Best get it into a turbo shop for a look. Link to comment https://www.fordxr6turbo.com/forum/topic/68740-is-my-turbo-stuffed-vids-n-pics/page/2/#findComment-1021967 Share on other sites More sharing options...
sly100 Member 290 Member For: 17y 1m 28d Gender: Male Location: Down South Posted 07/07/10 07:47 AM Author Share Posted 07/07/10 07:47 AM (edited) hahah yeah the clunking noise was in/outwards movement... doesn't sound healthy at all does itI took it in to the shop a few weeks ago now which I mentioned above haha.. he reckoned it was all within tolerances, but the bearings are worn, no visible damage to the impeller so he said about $800 to rebuild it... hopefully everything goes to plan.. he even said I could drive it and it should be fine for a while..but the car is now off the road for: turbo rebuild, new oil feed, oil temp and pressure gauges, full slotted rotors and pads, zf service and hopefully a tune pending on the tax return... Edited 07/07/10 10:51 AM by RHR No need to quote above post. USE FAST REPLY Link to comment https://www.fordxr6turbo.com/forum/topic/68740-is-my-turbo-stuffed-vids-n-pics/page/2/#findComment-1022371 Share on other sites More sharing options...
Ricky N Member 93 Member For: 16y 1m 13d Gender: Male Location: QLD Posted 07/07/10 10:31 AM Share Posted 07/07/10 10:31 AM (edited) Just out of curiosity what turbo shop did you take it to that told you it was within tolerances? Edited 07/07/10 10:52 AM by RHR No need to quote above post. USE FAST REPLY Link to comment https://www.fordxr6turbo.com/forum/topic/68740-is-my-turbo-stuffed-vids-n-pics/page/2/#findComment-1022422 Share on other sites More sharing options...
sly100 Member 290 Member For: 17y 1m 28d Gender: Male Location: Down South Posted 10/07/10 02:28 AM Author Share Posted 10/07/10 02:28 AM Adelaide Turbo Services.his exact words were 'its a ball bearing turbo so they have a bit more play than other turbos, but its within tollerances'he said he rebuilds 1 xr6 turbo a week, and hes a distributor for garrett... Link to comment https://www.fordxr6turbo.com/forum/topic/68740-is-my-turbo-stuffed-vids-n-pics/page/2/#findComment-1023253 Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 22y 14d Gender: Male Location: stanthorpe wine capital of qld. Posted 10/07/10 02:46 AM Share Posted 10/07/10 02:46 AM I would be worried if he thinks that is within tollerances. shaft off centre is not within tollerances.Ian Link to comment https://www.fordxr6turbo.com/forum/topic/68740-is-my-turbo-stuffed-vids-n-pics/page/2/#findComment-1023258 Share on other sites More sharing options...
sly100 Member 290 Member For: 17y 1m 28d Gender: Male Location: Down South Posted 10/07/10 02:54 AM Author Share Posted 10/07/10 02:54 AM haha that's not good.. what sort of price am I looking at for all the internals.. is it worth rebuilding or buying brand new? Link to comment https://www.fordxr6turbo.com/forum/topic/68740-is-my-turbo-stuffed-vids-n-pics/page/2/#findComment-1023259 Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 3m 18d Gender: Male Posted 10/07/10 05:21 AM Share Posted 10/07/10 05:21 AM little bit of play there back and forward, but dont worry about it. wait until the turb blows smoke then shes buggered or else u are throwing money away. Link to comment https://www.fordxr6turbo.com/forum/topic/68740-is-my-turbo-stuffed-vids-n-pics/page/2/#findComment-1023304 Share on other sites More sharing options...
CANOE Member 2 Member For: 12y 24d Posted 30/05/13 08:16 AM Share Posted 30/05/13 08:16 AM I have seen him twice for rebuilds and im up for another!! Link to comment https://www.fordxr6turbo.com/forum/topic/68740-is-my-turbo-stuffed-vids-n-pics/page/2/#findComment-1394224 Share on other sites More sharing options...
julesk_1972 Member 267 Member For: 12y 9m 10d Gender: Male Location: Perth Posted 01/06/13 06:52 AM Share Posted 01/06/13 06:52 AM I have seen him twice for rebuilds and im up for another!!Wtf is going on with all the rebuilds?? Link to comment https://www.fordxr6turbo.com/forum/topic/68740-is-my-turbo-stuffed-vids-n-pics/page/2/#findComment-1394818 Share on other sites More sharing options...
